Can anyone help me with this please? Is it a bug?
I am playing some .aif files, Plex reads them ok, but when I play them using Plexamp I get
that they are being transcoded… but yet on Plex it’s showing as direct play?? Can anyhow one answer this for me at all please? Many thanks
PlexAmp will cache several songs ahead so when it starts playing, the server doesn’t know if the cache was made from a transcode or the original. It doesn’t see that since it’s already been done so it thinks it is direct playing. What you see in PlexAmp is correct.
You cannot rely on the Plex dashboard as Plexamp pre-caches the file in some cases. The truth is shown in the Plexamp display. Plexamp supports PCM inside of AIFF but perhaps there’s something else? A log would show.
Don’t know if this helps… it’s compressed aiff
I’m missing something, help!
What is going wrong? Is it not playing? The Plexamp screen looks OK.
You say “it is being transcoded” - where do you see that?
Edit: Oh, I see it. “Opus” in the Plexamp screenshot.
Don’t have a melt down now… :face_with_peeking_eye:
Loooooogs.
Plexamp-Logs-2022-05-24-2.zip (149.7 KB)
My apologies! Many thanks for looking into this for me…
It’s not a supported variant. Convert it to a better codec which will save on space and be more compatible.
May 24, 2022 09:52:55.366 [0x6fce3000] INFO - Media: Passing on an item with bitrate 816 and codec 'adpcm_ima_qt'.
May 24, 2022 09:52:55.366 [0x6fce3000] INFO - Media: Couldn't find item with supported codec and bitrate under 0, transcoding.
Many thanks for your information!
Much appreciated!
