Can I have access to cable channels in Canada or only to the OTA channels...
Hello, I’m trying to figure out if I will be able to have access to the cable channels listed under “lineups” or not. I read posts that say we need a settop in Canada which makes Plex Live TV redondant in Canada. I want to cut the cord with my cable provider. Is Plex the solution or not? If not, what are the best options in Quebec, Canada?
Can you get a cable card from your cable provider?
If so yes…
Thanks nokdim. Seems like cablecards are not available anywhere in Canada:(
