Can I look through Plex TV Series agent data?
I have a problem with one show where everything is shifted because the data plex is pulling with the Plex TV Series agent doesn’t think it’s the first episode of the season. So how can I see where Plex thinks that episode is? I know how to go to thetvdb.com and themoviedb.org, but where’s the Plex TV agent data at?
Does any of these websites list the episodes as you require them for your files?
Yes
(but that’s too short of a reply for the forum apparently so here’s some extra stuff to make it long enough to post it)
Edit the tv show at its top level.
Go to the Advanced tab
set “Episode ordering” to the source which has their episodes listed just right for your files.
Refresh Metadata of the whole show.
Ok. I’ll give that a try when I get home.
I guess that means we don’t have a way to see the Plex data then. If we have a problem we just should pick tvdb or moviedb instead.
