Version 4.34.4
I’d like for Plex to match based on TMDB id. I have my directory structured using TMDB Ids, like this:
├───2316
│ └───7240
│ └───170135
│ └───170132
│ └───170134
│ └───170133
│ └───170130
2316 is the Series ID for “The Office”
7240 is the Season ID for Season 1
Under that are all of the episode IDs.
Is there any way for Plex to understand this? Any settings to switch to using IDs?
Yeap, you can use tmdb ids (I use them for everything) but not as you outlined. They need to use this type of format …
The Office (2001) {tmdb-2996}
The Office (2005) {tmdb-2316}
The id needs to preceded by tmdb- and it needs to be within {} brackets. The () is optional but I use it myself for my libraries. Plex does not use season ids to my knowledge only at the show or movie level.
Ah, that’s unforunate. And Plex is not open source, right? I can’t write code and add my own features?
Nope, not open source. It’s their code and theirs alone.
Question… how do you manage your file structures with only numbers as reference?
Just curious about your setup being done this way.
I was curious too… With only ids it world be difficult to find things quickly when there is large amount of folders.
I’m a software engineer and I’ve been a streaming site, complete with databases and other layers. It’s a whole system that I’ve build and it relies on this folder structure. I also built a tool that calls the TMDB API and gives me series and episode data.
I guess in theory you could name the top level folder like this…
{tmdb-2996}
{tmdb-2316}
and it should work but won’t for series/seasons under that. They would need to match the SxxExx naming.
Ah! Gotcha! That’s pretty interesting and in that context makes sense.
Two pieces of software that come to mind - but based on your use you’re probably beyond them - are FileBot and Jellyfin. If you weren’t already aware of them they might be worth checking.
FileBot is a pretty comprehensive media renaming\matching software that has automation and CLI functionality that might be worth tapping as it can do the “plex friendly” naming including TMDB references … might be useful as reference at least for ideas for your own naming automation.
You might also look at Jellyfin for a media center as it is open source and more customization friendly. It’s pretty popular with more tech savvy folks (Plex is very consumer friendly) and as a software engineer you might find it more flexible for your setup.
