Server Version#: 1.43.0.10492
Player Version#: Plex for iOS 2026.0.1 (1523)
I just moved and tried setting up my Plex server on my new network (new ISP). Watching Plex within my network works fine. On my old network, you can only access Plex remotely if you connected via Tailscale. On my new network, I can’t connect to the Plex server remotely when using Plex for iOS, Plex for AppleTV or Infuse for either.
I don’t believe the problem is with Tailscale. The reason is because on the same iPhone where remotely connecting via Tailscale and Plex for iOS doesn’t work. I can open my browser and access the Plex server via http://tailscalemagicdns:PORT
I confirmed that that address is still populated under Settings > Network > Custom server access URLs.
Confirmed in Settings that Remote Access is still disabled. Confirmed that the Tailscale IP addresses haven’t changed and are also a way to access the Plex server directly from browser.
Server:
- Plex Media Server installed via macos installer
- Tailscale installed via homebrew
Old Network: ATT Fiber with ISP provided router
New Network: Verizon FiOS with Unifi Cloud Gateway Fiber
Been working on this for a few days and cannot figure out what specifically broke and where.
