Can not Add Movies or Series to be displayes @ Plez
Server Version#:
Since Yesterday I Can not Add Any sort of media to be displayed at plex platform???
Some context will greatly improve the chances that somebody might be able to help.
e.g. what version of Plex Media Server do you have installed and on what platform (your post is tagged as server-windows… I just want to be sure), are the files added but not matched or not added at all, have you checked for permission issues for Plex to access your media, is your server configured to automatically scan your libraries or do manual scans fail as well… and last not least the common: what types of files are you trying to add and how are they named/organized within the library folder?
TL;DR: lots of questions…
plex vesion : Version 1.32.5.7349
Platform: Server windows
The files are added to the server I subscribed with (whatbox.ca)
The files are Movies or series .
I already have so many are ok since 2 years ago
But now it doesn,t shows at the plex platform>
Other media before yesterday is Ok shown .
The server is set to configure automatically
Any details about that part?
I tried Manual Scan but nothing is changed.
Such as :
in Serires folders
All Series/Special Ops: Lioness (2023)/Special.Ops.Lioness.S01E08.1080p.HEVC.x265-MeGusta[TGx]/Special.Ops.Lioness.S01E08.1080p.HEVC.x265-MeGusta.mkv
Ep01…Ep07 Already recogmized with the same form.
in Movies Folder:
/2021 English Movies/Nobody.2021.1080p.BluRay.x265-RARBG/Nobody.2021.1080p.BluRay.x265-RARBG.mp4
Before yesterday was working perfectly,
and I did not change any setting.
I wounder if there is any update coming soon , might solve the proble,
May I ask if there is a limit number of movies that could exceed the numbers permitted to?
I Stooped the application , from the server (whatbox.ca) and played it again>
and it Solved the problem>
it is starting scaning again .
thank you very much for your effort…
you are awesome.
