Can someone help, A problem has been detected with a core component of Plex Media Server
I have tried many times, 32bit version and 64bit version. But everytime it shows the same problems. Can someone help me to solve it?
Logs.zip (1.9 MB)
I also update to windows 11, it still the same issue.
Logs.zip (155.2 KB)
Do you have this folder? And it has does in it?
C:\Program Files\Plex\Plex Media Server\Resources\Plug-ins-8463ad060\
If not, something didn’t install. Try a repair install.
I have this folder.
There are a bunch of errors in your system.log file. This indicates something can’t be loaded that PMS needs. I thought it was due to those files being missing, but if they are there, then you might have a bigger problem. I can’t tell what’s wrong.
OK, thanks a lot.
