Server Version#: 1.31.0.6654
Player Version#: Plex Web 4.87.2
Tuner Make/Model: ErsatzTV
Guide/Lineup name: ErsatzTV
Using XMLTV?: Yes
Channel number/Name: N/A
I am having an issue with adding XMLTV EPG using both ErsatzTV and DizqueTV. I have used DizqueTV before and it was setup fine, but maybe that old setup is causing a problem. It is able to find the tuner just fine, but when I go to add the .xml URL it shows invalid or missing file. I looked at the logs and I’m seeing http 200s, but it does appear that it is able to see that url. I tried the same setup for ErsatzTV on Jellyfin just to see if there was an issue with ErsatzTV and it worked fine. I tried removing entries from the media_provider_resources table, but that did not fix my issue. Let me know if other logs are needed. Thanks in advance!
