Cannot add more than 23 separate libraries after update
I am keeping my music library separated into different styles and country. I have noticed a change in available space to add libraries after the recent update that included adding the checkmark for “Merge recently added items”. After I have added a few libraries, the “add library” button at the top of the page (Dashboard-Manage-Libraries) is going out of sight and reach. I can increase the window size using apple-minus a few times, and the button reappears again, but that only works up to a certain point. After having added 23 libraries, it’s impossible to add more. I feel this behavior was not there before the recent update. I had been able to scroll through that page with ease, and get to the add library button. I suspect some formatting for that page has been messed up with the update.
This happens on the Plex-web app, using Mac Safari browser.
This is my first post, please let me know if other info needed.
Here is a screen shot, of what I don’t see:
On the left, the first two libraries, and on the right a darker sliver but no add library button.
is it only in Safari? Have you tried other browsers? Do you see the add library :heavy_plus_sign: button next to server name (Click MORE on home menu side bar to see full server list)
Plex
Thank you for your answer.
Yes, it seems to work fine in Chrome. What could be the explanation? It really looked to me that the scrolling behavior had changed in Safari. Maybe I need to do a restart of Safari?
No, it’s the same thing after restarting computer and Safari. The scrolling in Safari is limited with a lot of (23) libraries.
Do you have any extensions or browser plugins enabled in Safari? Can you try in a Safari Private window?
We created a server with 24 libraries and cannot reproduce.
it’s the same thing in a private window. Maybe I should mention also that I still use High Sierra as the OS, and Safari has the Version 11.1.2.
I guess I can live with it, using Chrome to add more libraries. The scrolling on the sidebar works fine for the mobile app.
Thanks.
