Cannot connect directly on local network
I have had my Plex server setup for a while now.
I have “full remove access” in the Remote Access tab. Port forwarding is enabled and working, router is set to communicate with cloudflare 1.1.1.1 DNS service.
Yet on my Xbox one, I can’t stream at higher qualities because it says I am connected indirectly. This was ever since I upgraded to 1.15.
Any help would be appreciated.
then you have to enable external access or it won’t work because cloud flare makes a connection via proxy server then it cannot reach inter IP conductors
