Cannot delete existing Tuner Setup
Hi there!
I have been running my IPTV feed into Plex via a HD HomeRun virtual tuner, and had to delete the previous tuner to change some settings from my IPTV provider.
When I attempted to reinstall it, Plex created a Golang tuner that only seems to look for an antenna or cable, and I haven’t been able to figure out how to delete it.
Any assistance would be appreciated
Need to clear out the media_provider_resources table in com.plexapp.plugins.library.db.
how do I do that??
I deleted those and it still comes up with this “stuck” Golang tuner that thinks it’s attached to an antenna and wants to scan the channels. Even when I enter the IP address for the Homerun and the XMLTV files in xteve
Delete the DVR.
When you set it back up, don’t enter a zip code.
There should be a link below the zip code box to add XMLTV guide.
That’s my main problem: it won’t let me delete the existing DVR … the button isn’t even showing!
What happens if you click the “Click here to use it” ?
You can verify that your database isn’t corrupted by either downloading it from the troubleshooting page or looking at the file system for backups that occur every 3 days.
What OS is this?
