Server Version#:1.14.1.5488
Player Version#:3.77.4
I have searched the forumn and cant really find a solution to my problem. I am running plex on server and cant delete files from web interface.
lets use Pictures folder for example located at /home/tim/Pictures
permissions for Pictures folder tim:tim with 755
files are permissions tim:tim with 664.
plex user is in group tim
below is log showing request for delete and it says it completes it but web interface says “There was a problem deleting this item”.
Log shows im authenticated on web as rockytoptim so I added that user and included it in both groups tim and plex. Still no luck.
Any help is appreciated.
Feb 05, 2019 11:43:51.171 [0x7ff828ffb700] DEBUG - NetworkServiceBrowser: found 1 SSDP devices via http://192.168.1.134:32469/DeviceDescription.xml
Feb 05, 2019 11:43:51.171 [0x7ff828ffb700] DEBUG - NetworkServiceBrowser: SSDP arrived: 192.168.1.134 (Plex Media Server: pop-os)
Feb 05, 2019 11:43:52.379 [0x7ff82effd700] DEBUG - Auth: authenticated user 1 as rockytoptim
Feb 05, 2019 11:43:52.379 [0x7ff8247fc700] DEBUG - Request: [127.0.0.1:60002 (Loopback)] DELETE /library/metadata/18 (7 live) GZIP Signed-in Token (rockytoptim)
Feb 05, 2019 11:43:52.382 [0x7ff82f7fe700] DEBUG - Completed: [127.0.0.1:60002] 400 DELETE /library/metadata/18 (7 live) GZIP 3ms 457 bytes (pipelined: 6)
Feb 05, 2019 11:43:57.964 [0x7ff8247fc700] DEBUG - Request: [127.0.0.1:60002 (Loopback)] OPTIONS /library/metadata/17 (6 live) GZIP Signed-in Token ()
Feb 05, 2019 11:43:57.964 [0x7ff82effd700] DEBUG - Completed: [127.0.0.1:60002] 200 OPTIONS /library/metadata/17 (6 live) GZIP 0ms 349 bytes (pipelined: 7)
Feb 05, 2019 11:43:57.969 [0x7ff82f7fe700] DEBUG - Auth: authenticated user 1 as rockytoptim
Feb 05, 2019 11:43:57.969 [0x7ff8247fc700] DEBUG - Request: [127.0.0.1:59982 (Loopback)] DELETE /library/metadata/17 (5 live) GZIP Signed-in Token (rockytoptim)
Feb 05, 2019 11:43:57.972 [0x7ff82effd700] DEBUG - Completed: [127.0.0.1:59982] 400 DELETE /library/metadata/17 (5 live) GZIP 3ms 457 bytes (pipelined: 4)
Feb 05, 2019 11:44:05.459 [0x7ff833289840] DEBUG - Shutting down with signal 15
Feb 05, 2019 11:44:05.459 [0x7ff833289840] DEBUG - Ordered to stop server.
Feb 05, 2019 11:44:05.459 [0x7ff833289840] WARN - Timed out waiting for server to finish.
Feb 05, 2019 11:44:05.459 [0x7ff833289840] DEBUG - Stopping server...
