Cannot Direct Stream - Atmos or DTS-X - Audio Passthrough
Server Version#: 1.23.1.4602
Player Version#: Xbox
I finally gave audio passthrough a try, hoping to get rid of my shield.
I notice it’s a bit choppy, when I went into details I noticed this.
Not really sure what this Reasons thing is on Atmos and DTS-X files
Also not really sure if it has anything to do with the choppiness
HEVC + Atmos
HEVC + DTS-X
HEVC + 5.1
5.1 seems to work fine
Xbox is set to Passthrough, When the movie starts, the xbox shows passthough
Receiver is picking the Atmos or DTS-X
Plex Dash - Doesn’t show any transcoding
So all those seem to be working fine
Though I have this odd message
what exactly does the plex dashboard show? are they direct STREAMing? if so, then you must determine why, as pass through is only supported with direct PLAY.
the most likely place to look is PGS subtitles, turn them off or switch to SRT subtitles.
Dashboard shows directplay…
Zero Conversion, Zero Transcoding
Also no subtitles…
Well without the specific details of your setup, and logs, all we can do is guess.
What tv, avr, do you have, how are they connected to the Xbox?
Have you restarted the Xbox?
Does an actual Blu-ray with truehd/dtshd play and pass through?
Not sure what my equipment has to do with it… It’s setup properly
Doesn’t matter, I will stick with my shield that thing just works for everything
