Hi
I would like to change some settings in plex, so 'm going on the plex webpage of the server computer, then parameters on top right corner, then If i go to all menus under Parameters and settings nothing happens, (just loading eternaly… and sometimes it display : server parameters are unavailable. what happens ?
Are you accessing the Plex web app using the local address?
e.g. http://127.0.0.1:32400/web if you’re on the same machine as the Plex Media Server or http://[PMS IP address]:32400/web otherwise?
hi anybody knows how to set up expressvpn or plex to work correctly in the same time ?
I’ve try to add all exe files of plex in the expressvpn split tunneling without any change.
I’ve still some trouble accessing plex parameters in this case.
