Why the "Fix Match" option does not appear?
Hello,
I’m using Plex (docker version) official image. Working very well.
But I have 1 TV Serie for which the matched show is not correct. So i want to manually fix it, but the option is simply missing from the menu. Any idea why ?
Also I notice sometimes this option is not right away available, I don’t get why too. Can you leave it always on, so we can always fix if a match is wrong without waiting ?
Thank you
Screenshot 2020-02-07 at 20.02.32|480x754
“Fix Match” is only available on the top level of a tv show.
Not on the Season level, not on the Episode level.
The easiest way to get to the top level is to click onto the title of the whole show.
Ohhh, thanks !
This is a bit tricky when the TV show has only 1 season, as we jump directly to the folder season and one does not necessarily think to move up, knowing there is only one season…
Thank you
I had the same problem and it was driving me crazy! but this suggestion worked
