Fix Match Is Not Displayed As An Option
Server Version#: 4.47.1
Player Version#: N/A
Many correctly named TV series have no match at all and the fix match option is not displayed in the “More” actions sub-menu.
I used to be able to manually fix these “no match” or incorrect matches. Now it no longer functions at all.
Any suggestions?
Known bug?
Make sure you’re selecting the “More” menu for the show itself, not a season or episode. Also, if the show is not currently matched at all, it will show “Match” instead of “Fix Match.”
