NeilF
August 21, 2024, 8:15pm
1
eg:-
MovieTitle.2024\
featurettes\
feature1.mkv
feature2.mkv
MovieTitle.2024{edition-DirectorsCut}.mkv
MovieTitle.2024{edition-TheatricalCut}.mkv
The featurettes refuse to appear on the Plex entry
tom80H
August 21, 2024, 8:59pm
2
Plex cannot currently deal with extras for multiple editions stored in the same movie folder. You’ll need to move each edition to its own movie folder and pick which edition should get the extras.
There’s a feature suggestion asking for Plex to support mixed-edition folders with shared extras.
I’ve been waiting for this feature for ages, but I got to say that in its current state it leaves a lot to be desired for.
https://support.plex.tv/articles/multiple-editions/
Downsides of the current implementation - 2022-08-19:
Library gets cluttered with multiple instances of the same movie
the “edition tag” is not displayed in the library, so you cannot distinguish the editions as all instances use the same name and thumbnail (unless you manually change the thumbnail)
the ‘edition’ tag is…
NeilF
August 22, 2024, 8:19am
3
MovieTitle.2024.DirectorsCut\
featurettes\
feature1.mkv
feature2.mkv
MovieTitle.2024.TheatricalCut\
OK! That’s got around it! Thanks! As you suggest, the features are only in the one version, but that’s fine!
tom80H
August 22, 2024, 8:42am
4
To be perfectly good, go with the official naming Schema and make that
MovieTitle (2024) {Edition-DirectorsCut}
Featurettes
feature1.mkv
feature2.mkv
MovieTitle (2024) {edition-DirectorsCut}.mkv
MovieTitle (2024) {edition-Theatrical Cut}
MovieTitle (2024) {edition-TheatricalCut}.mkv
As a side note: Edition titles can have spaces… so you should be fine to make that {edition-Director‘s Cut}
and {edition-Theatrical Cut}
system
Closed
November 20, 2024, 8:43am
5
