Diiferent Extras/Featurettes for Different Versions of a Movie
I have the Theatrical version of Blade Runner and the Final Cut. They are both in separate folders and each with their own set of Extras. (I have a number of movies like this)
Plex will only see one set of extras. It will either have the Theatrical extras for both the Theatrical version and the Final Cut or if I Refresh Metadata it will have the Final Cut extras for the Theatrical version and the Final Cut.
It would be good if Plex could see both sets of extras separately.
The Theatrical extras with the Theatrical version and the Final Cut extras with the Final Cut version.
have you tried using the new editions feature Multiple Editions | Plex Support ( it is not the same as versions)
Thanks for your reply.
I have tagged the movies as different Editions.
It doesn’t effect the Extras.
I consider this a bug report, not a feature request.
Fair call.
How do you report a bug?
You just did. :slight_smile:
Awesome
:+1:
Do bugs get fixed?
Or do they just get reported?
Are the two edition in separated folders or do they share a folder?
Did you create a common folder for the movie title, and then separate sub-folders for the editions?
Please show a directory listing, so we can understand and recreate the issue better.
They are both in separate folders.
probably need to see your server logs after adding an extra and refreshing metadata for that movie. I can’t reproduce unfortunately
In your example above does the regular Logan version have its own different featurette?
Yes I made a deleted scene one for the regular Logan and each has the correct one
I just remembered something that I think is linked to this problem. I recently watched the Directors Cut of Cinema Paradiso over several nights. When I went back to watch it, in the Continue Watching section, it had both versions of Cinema Paradiso when I had only been watching the Directors Cut. I have recreated this in the screenshoot.
Somewhere in the Plex code it sees two different versions of a movie as the same movie.
That is a different issue than the extras but maybe relate to cause. Is that doing the same for Bladerunner? it would suggest Cinema Paradiso ones you have are just split apart and renamed without an edition title
Does one of them have the edition info? it will be right after the GUID in the plex media info xml if it s there. it will probably shed light by looking at that for them
my logan noir looks like this ( the regular one does not have an edition title)
guid="plex://movie/5d776abffb0d55001f54faa3" editionTitle="Noir"
also just made a different edition with a random name and all three i made have different watch states
Plex
