Cannot play (most) 'live TV and DVR' items on android but all work on Web
I’m experimenting with Xteve and IPTV, running plex on my readynas and it works flawlessly on Web (so I’m assuming this is an issue with the android app).
Anytime I click on any listing in the ‘What’s on’ or ‘Guide’ tabs I’m shown the ‘Unable to play media’ Toast and the below logs are produced. If I select anything under ‘Browse’ in the android app - it plays. (Plex Web will play regardless of what Item I select or from where). The items under the ‘browse’ tab on Android appear to be a limited subset of the channels available (different each restart)
Server Version#: 1.20.1.3252 (ReadyNas OS6 - ARM)
Player Version#: commit #e97d660a / 8.6.0.20351
Reading the logs - this seems to be the pertinent part (mobile app logging - nothing appears on the server - from what I can see):
09-17 22:33:44.522  i: [OneApp] User can execute command without restrictions because he is entitled.
09-17 22:33:44.525  i: [PlayQueues] Cannot create remote PQ because item is not a library or playlist item or radio or gracenote collection.
09-17 22:33:44.526  e: [PlayQueues] Can't create remote PQs and item does not support local PQs. Returning null.
09-17 22:33:44.526  i: Showing toast: Unable to play media
09-17 22:33:45.689  i: [LiveAiringMediaItemsMonitor] Cancelling change detection
I’ve installed Plex on a NUC and have the same behaviour
I eventually solved this by removing and re-adding the tuner several times, since then it has worked reliably
