Cannot refresh program guide
I’m running on FreeBSD (well freenas in a jail) and i just cannot refresh the program guide :frowning: it just wont work so is there any way you can help please? I’ve attached a movie of it youtu.be/7V679l_h2Xo and the logs from my server. It’s been working well for months and months, so strange it’s suddenly stopped. Any advice much appreciated!
Christopher
Just a small update here’s the diff on the logs of me doing this:
so it seems to me that this probably is the naughty line; that somewhere oauth is unhappy???
Jan 26, 2018 05:15:48.145 [0x80a410c00] ERROR - EPG: JSON parse error. Data from request is {"errorCode":1005,"errorMessage":"invalid_lineup_id"}
Jan 26, 2018 05:15:48.145 [0x80a410c00] WARN - EPG[onconnect]: Failed to load EPG.
Jan 26, 2018 05:15:48.145 [0x80a410c00] DEBUG - Database: Shutting down.
Any pointers as to where would be much appreciated. Only other thing that looks suspicious is:
Jan 26, 2018 05:15:46.533 [0x80a410c00] DEBUG - Running forward migration 20170707000000.
Jan 26, 2018 05:15:46.533 [0x80a410c00] DEBUG - Captured session 0.
Jan 26, 2018 05:15:46.533 [0x80a410c00] DEBUG - Captured session 1.
Jan 26, 2018 05:15:46.533 [0x80a410c00] DEBUG - Captured session 2.
Jan 26, 2018 05:15:46.533 [0x80a410c00] DEBUG - Captured session 3.
Jan 26, 2018 05:15:46.533 [0x80a410c00] DEBUG - Captured session 4.
Jan 26, 2018 05:15:46.535 [0x80a410c00] INFO - SQLITE3:0x10, 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Jan 26, 2018 05:15:46.537 [0x80a410c00] INFO - SQLITE3:0x10, 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Jan 26, 2018 05:15:46.539 [0x80a410c00] INFO - SQLITE3:0x10, 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Jan 26, 2018 05:15:46.541 [0x80a410c00] INFO - SQLITE3:0x10, 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Jan 26, 2018 05:15:46.543 [0x80a410c00] DEBUG - Completed forward migration 20170707000000.
But here this just seems like it’s to do with some database migration which does seem to complete ok.
This has been seen recently and believed to be due to Gracenote discontinuing an EPG. This is being looked into by the development team but the only way to fix it at the moment is to delete the DVR and recreate it
You should not lose your existing subscriptions
Not only have i not lost my subscriptions but it’s remembered my channel mapping, which ones i wanted … as well. Thank you so so much!
