I’m trying to configure my computer with Plex DVR with silicondust HD HomeRun ATSC Digital TV Dual Tuner.
The channels seem to scan 49 channhels and then I get to the next screen where it says:
Refreshing EPG (0%)—Initializing
It stay here for a while and nothing happens
When I click on the Program Guide I get this:
The Program Guide is empty
Please verify your channel mappings and refresh the Program Guide
Any suggestions?
you might want to post logs, they can’t fix it if they don’t see the problem. like this
Running windows 10 version 1607 build 14393.1066 with Plex version 1.5.5.3634. The EPG will download the info but can not update the file.
" ERROR - Couldn’t rename file C:\Users\core\AppData\Local\Plex Media Server\Plug-in Support\Databases v.plex.providers.epg.onconnect-9de5568a-378d-4b70-ab8b-2593927f70d2-loading.db to C:\Users\core\AppData\Local\Plex Media Server\Plug-in Support\Databases v.plex.providers.epg.onconnect-9de5568a-378d-4b70-ab8b-2593927f70d2.db: The process cannot access the file because it is being used by another process"
similar problem here. When I click on “refresh program guide” it actually progresses to 100% and shows that it has downloaded almost 3000 airings. Then goes to “optimizing guide” and finishes. However, when to go to look at the guide it still says “The Program Guide is empty”.
Plex Version 1.5.5.3634
UPDATE: I was looking through the logs and noticed an entry that a file was locked from writing:
Apr 29, 2017 20:18:46.618 [12500] ERROR - Couldn’t rename file C:\Users\ck\AppData\Local\Plex Media Server\Plug-in Support\Databases v.plex.providers.epg.onconnect-3656ff75-429c-40d6-ab23-1c2ab5a0407b-loading.db to C:\Users\ck\AppData\Local\Plex Media Server\Plug-in Support\Databases v.plex.providers.epg.onconnect-3656ff75-429c-40d6-ab23-1c2ab5a0407b.db: The process cannot access the file because it is being used by another process
A simple windows reboot allowed that file to be written to. Not sure what caused this, but thought I would share the solution I found.
I’m getting the error below. I keep trying to refresh and it kept going up about 1% on every refresh, but now I’m stuck again at 12%:
May 03, 2017 10:20:51.486 [0x70000844c000] ERROR - downloadContainer: expected MediaContainer element, found html
May 03, 2017 10:20:51.486 [0x70000844c000] WARN - MediaSub: No container available for /tv.plex.providers.epg.onconnect:2/metadata/com%2Egracenote%2Eonconnect%3A%2F%2Fshow%2F3560360
May 03, 2017 10:20:51.488 [0x70000844c000] ERROR - downloadContainer: expected MediaContainer element, found html
May 03, 2017 10:20:51.488 [0x70000844c000] WARN - MediaSub: No container available for /tv.plex.providers.epg.onconnect:2/metadata/com%2Egracenote%2Eonconnect%3A%2F%2Fshow%2F184224
May 03, 2017 10:20:51.491 [0x70000844c000] ERROR - downloadContainer: expected MediaContainer element, found html
May 03, 2017 10:20:51.491 [0x70000844c000] WARN - MediaSub: No container available for /tv.plex.providers.epg.onconnect:2/metadata/com%2Egracenote%2Eonconnect%3A%2F%2Fshow%2F7931557
May 03, 2017 10:20:51.493 [0x70000844c000] ERROR - downloadContainer: expected MediaContainer element, found html
May 03, 2017 10:20:51.493 [0x70000844c000] WARN - MediaSub: No container available for /tv.plex.providers.epg.onconnect:2/metadata/com%2Egracenote%2Eonconnect%3A%2F%2Fshow%2F9898935
I have the same thing happening to me right now. I refresh the EPG but it never writes the file and my program guide is empty, which means none of my shows are being recorded. When I try to access the file manually it says “The action can’t be completed because the file is open in Plex Media Server”. Seems like it’s in a deadlock.
Windows Server 2012 R2, 6.3.9600, fully updated
May 08, 2017 16:47:39.198 [1436] ERROR - Couldn’t rename file C:\Users\Administrator\AppData\Local\Plex Media Server\Plug-in Support\Databases v.plex.providers.epg.onconnect-cd0d2d36-97e5-4922-aabd-5460078ae0a7-loading.db to C:\Users\Administrator\AppData\Local\Plex Media Server\Plug-in Support\Databases v.plex.providers.epg.onconnect-cd0d2d36-97e5-4922-aabd-5460078ae0a7.db: The process cannot access the file because it is being used by another process
Have you rebooted the server? Another thread Plex Employee asked that we reboot and try EPG refresh after reboot. Worked for others on that thread including myself.
Same issue today as well. PMS on Mac mini running latest Plex Pass release.
All of a sudden today EPG is empty and no recordings made. Had to force a refresh again and it’s moving very slowly. This is the 3rd time this week that I’ve had to force an EPG refresh.
@jayz78 Have you rebooted the server? Another thread Plex Employee asked that we reboot and try EPG refresh after reboot. Worked for others on that thread including myself. Since reboot I have been retrieving EPG data each day. Just checked and have 14 days of data so it is still working for me.
I had a similar issue where the guide data expired today and no shows recorded. I checked the schedule and there was no guide data available. I attempted to refresh it but it failed. I rebooted and was still unsuccessful in removing the file lock.
My solution was:
Stop the Plex Update service (Services.msc)
Exit Plex from the tray icon
Move the tv.plex.providers.epg.onconnect-* files **from **the %LocalAppData%\Plex Media Server\Plug-in Support\Databases\ folder **to **the desktop
Start Plex Update service (Services.msc)
Open Plex
The files were immediately rebuilt with no data. I performed a refresh of the EPG and it successfully updated the guide.
It appears that it was unable to write to the DB-WAL file during the optimization step of the EPG update. The file size of the original DB-WAL was 1.02 MB whereas the newly created one was the full download size of the EPG at 58 MB. I also noted that the original Data Base file was created during the last update to my Plex Server installation. It had been working between then (4/28/17) and today. It was the DB-WAL file access causing the issue.
I will continue to monitor the EPG to ensure this doesn’t happen again.
Went to watch a show, and found my program guide was empty as of today. Looked in the logs, and there were errors about not being able to delete some tv* files because they were in use by another process. I exited Plex, deleted all the C:\Users\Mark\AppData\Local\Plex Media Server\Plug-in Support\Databases v* files, re-started Plex, and then the guide was able to re-build.
My guide was stuck on “Refreshing (0%) - Initializing” but I followed your instructions. Removing those DB files did the trick - the guide is rebuilding itself from scratch. Seems like maybe that file was corrupted?
On OS X these three files with names beginning “tv.plex.providers.epg.onconnect” are in ~/Library/Application Support/Plex Media Server/Plug-in Support/Databases
