Server Version#: 1.25.8.5663
Player Version#: any
Tuner Make/Model: any
Guide/Lineup name: any
Using XMLTV?: yes
My first tuner in Plex is configured to use an XMLTV EPG from a local file, which works fine. Now, I want to add a second tuner which uses the EPG data provided by Plex. However, when adding the second tuner, there is no selection screen for the EPG type, it just shows the form to fill in the path to the XMLTV file.
Is this intended? Can’t we use two tuners with different EPG sources?
Regards,
Chris
