Adding 2nd Tuner, but wont allow me to choose a 2nd source of EPG
Server Version#: Current
Player Version#: Plex
Tuner Make/Model: Homerun
Guide/Lineup name:
Using XMLTV?: No
Channel number/Name:
When I add a 2nd group of channels, i cannot pick a 2nd country to get the correct epg.
I have access to Swedish and Danish channels and have each one on a different tuner, but I add the swedish and fix the epg. but when i add the 2nd and choose denmark for the EPG it still gives me swedish
Unfortunately that’s not available. There is a mod that you can do that works but it’s not ideal. Here’s the link go all the way to the bottom and read up on the past couple post will tell you how to do it.
