Server Version#: 1.25.5.5492
Player Version#: n/a
Tuner Make/Model: HDHomeRun FLEX 4K
Guide/Lineup name:
Using XMLTV?: YES
Channel number/Name:
I’m noticing that if I have two, or more, tuner sources whatever epg method I pick for the first tuner is forced on the second, and other subsequent tuners. It doesn’t seem to let the user mix and match. I have a need to have one tuner use a custom EPG via an XMLTV file while the other should use the built in EPG.
For example:
If I add Tuner1 and select the build in EPG method, when I try to add Tuner2 I have no option to pick XMLTV method-- it will only use the built in EPG.
If I add Tuner1 and select the build in XMLTV method, when I try to add Tuner2 I have no option to use the build in EPG method-- it will only allow entry of an XMLTV file/location.
