Cannot skip intro on samsung tv 2020
Server Version#: 1.28.2.6151
Cannot skip the openings with some files (usually HEVC) but not all…
What shows aren’t working?
Not all shows qualify for that feature depending on how the intro is configured
Are you sure the files have been scanned for intros either when they were added or during routine maintenance?
Do the shows you’re trying work on any of your other supported devices?
Do you have any other copies of the same file’s you’re trying?
the most of them are anime shows
and yes, theay are supposedly ready for the feature. the button appears and when i choose to skip the intro… it keeps loading… and never does it.
(if i do the same on android it works ok)
