Using multiple versions of Plex I cannot seem to get my Hauppauge tuner to work! It will scan channels, and tune for about 5 seconds then stop and never work again until I remove and add it back. I’ve tried Ubuntu, Windows 10, and Windows 2016 Server (my real machine it runs on).
I can get Plex to pick up the card, scan for channels, and tune only one time before it stops working. I get a cannot tune to channel error and something about recording.
Will attach logs if needed. I’ve tried a few versions of plex too nothing seems to help.
I am having the same issues with the same tuner. It was working fine at one time but now it just won’t tune to any of the channels. Looking at the server, I see that all the channels are showing strong signal.
This just started happening in the past month so I am assuming it is an issue with Media Server update during that time?
Thanks for reply. Decided to give it a few more updates and see if it was resolved but this time I’m getting Cannot tune to channel (No Parts) error message. Exact same thing happens - add tuner, tunes and then fails.
Errors I found:
Apr 08, 2019 23:07:02.991 [10332] Error — Unable to find title for item of type 5
Apr 08, 2019 23:07:03.006 [10332] Error — Unable to find title for item of type 5
Apr 08, 2019 23:07:28.660 [10332] Error — Failed to start session.
Apr 08, 2019 23:07:28.660 [10332] Error — DVR:Recorder: Unable to create transcode session or session failed to start.
Apr 08, 2019 23:07:28.660 [10332] Error — DVR:Recorder: Error 16 (Recording failed. Please check your tuner or antenna.) starting the record, shutting things down.
Apr 08, 2019 23:07:28.660 [10332] Error — DVR:Grabber: Starting media grab failed.
Apr 08, 2019 23:07:28.660 [10332] Error — Unknown metadata type:
Apr 08, 2019 23:07:28.660 [8584] Error — DVR:Subscription: Rolling media grab failed to start.
Apr 08, 2019 23:09:31.202 [8292] Error — LPE: unknown item 28655.
Apr 08, 2019 23:09:31.202 [8292] Error — Sync: failed to generate query for path library://c72d7feb-0d25-46fa-97bf-9fb72cf6917b/item/%2Flibrary%2Fmetadata%2F28655 in sync item 32235231
Apr 08, 2019 23:09:31.202 [8292] Error — Sync: skipping items for sync list 30178507, sync item 32235231: unable to generate sync set query
Apr 08, 2019 23:10:42.957 [10996] Error — [PlexRelay] kex protocol error: type 7 seq 11
Apr 08, 2019 23:10:46.349 [9892] Error — ClientProfileExtra: video transcode target already exists for streaming hls
Apr 08, 2019 23:10:46.443 [1376] Error — ClientProfileExtra: video transcode target already exists for streaming hls
From other places on the forum this is not just an issue with this device but many others that are claimed to work fine. Doesn’t seem to be a priority to be resolved.
So, I was able to improve my stability by cleaning out all tuner driver’s using a driver cleaner. I reinstalled the latest driver from WinDVR 8.5 software and now the tuner works much better.
