Cannot view or record OTA Channel
Hello,
Running version 1.12.1.4885.
I have a problem with one channel - 68.1 in DFW Area (ION) - KPXD. I cannot view live TV, nor do recordings work on the channel. I’ve tried on a test Plex install as well – same issue. When viewing the channel via VLC or via Emby server – it is fine, with no issue. Plex can access other channels for Live TV or recording w/o issue.
Tuners are HDHomeRun EXTEND and HDHomeRun Quatro (separate antennas).
The symptoms on Plex are – it will initially load the first frame of the video, then constantly spins and never actually plays the channel, nor records.
Here are what I think are some relevant log entries:
Mar 30, 2018 11:24:31.865 [0x7fa0647ff700] INFO - AutoUpdate: no updates available
Mar 30, 2018 11:39:42.022 [0x7fa0767ff700] ERROR - Unable to find title for item of type 5
Mar 30, 2018 11:39:42.023 [0x7fa0767ff700] ERROR - Unable to find title for item of type 5
Mar 30, 2018 11:39:44.542 [0x7fa078bff700] ERROR - Error issuing curl_easy_perform(handle): 7
Mar 30, 2018 11:40:12.448 [0x7fa0767ff700] ERROR - Error issuing curl_easy_perform(handle): 7
Mar 30, 2018 11:40:22.142 [0x7fa067ffd700] ERROR - Unable to find title for item of type 5
Mar 30, 2018 11:40:22.143 [0x7fa067ffd700] ERROR - Unable to find title for item of type 5
Mar 30, 2018 11:40:23.816 [0x7fa0767ff700] ERROR - Error issuing curl_easy_perform(handle): 7
Mar 30, 2018 11:42:32.158 [0x7fa077bff700] WARN - Timed out waiting for segment.
I’ve also uploaded ~11 seconds of the broadcast from the channel based on a similar issue seen in another post here.
Please let me know what other troubleshooting info you might need.
Thanks,
-Matt
I’ve loaded the latest beta (1.12.2.4929) on my test server. I am now able to get it to record from the channel in question, however - the media video and audio playback is very choppy.
Logs attached from record and then playback.
Hi all,
I’ve noticed that this issue has gotten better in the later beta releases, i.e., 4929, 4947, and 4973. I am therefore assuming that Plex is trying to fix.
I have a few updates on the issue:
  • with the new updates, when hitting an HDHR Quatro – the issue seems to be resolved. The only strange entry I get in the logs is ones like these:
Apr 18, 2018 11:44:55.740 [0x7f01adbff700] ERROR - [Transcoder] [mpeg2video @ 0x14f7040] Invalid frame dimensions 0x0.
  • with the new updates, when hitting an HDHR Extend (using “heavy” transcode profile), I’m still seeing audio stuttering, and the following error:
Apr 18, 2018 10:52:09.512 [0x7fe2113ff700] ERROR - [Transcoder] 3589780 frame duplication too large, skipping
If I disable transcoding for the Extend, then I simply get the “Invalid frame dimensions” error in the log and can go from there.
-Matt
