Hi there, I have a particularly odd scenario going on that I’d appreciate some guidance on because it’s got me stumped.
Currently, I have a smart TV and my plex server on the same network. If I connect my TV to the wifi, then Plex will work locally (i.e. is available as a non remote connection). However, if I connect my TV via ethernet to the LAN, Plex will not work as a local connection, but rather requires it to be a remote connection.
Unfortunately the wifi isn’t strong enough to just keep it on that, and I don’t want to have to use data to use the ethernet.
My network setup is a simple modem -> router -> switch -> devices.
Anyone have any idea why the ethernet may be unavailable as a local connection or how I can get this working? I’d very much appreciate it, thanks.
