Can't add URL for Bestoftheleft podcast
this URL errors when I try to add it to Plex podcasts
https://www.bestoftheleft.com/
This URL works in Windows 10 EDGE but is not found in the Plex add podcast URL dialog.
any help is greatly appreciated.
thanks
R_Schalker,
I’ve had the same problem trying to find podcasts as well and one day, PLEX may be able to replace BeyondPod, my go-to app for podcasts right now.
My workaround:
When I can’t convince PLEX that the podcast actually exists, I’ve found the OPML option to be a good workaround. Find the podcast in another program, save it as a feed, and then export to OPML. Then, PLEX lets you import the file. the capability varies from program to program. but for now, its what I’m doing.
Bob
