Can't connect to server with Plexamp
I have two audio libraries on my server (music and audio books). If I start Plexamp and login with the account I used for the server, I get an error message that no server could be found even tough I can connect to the server with the standard Plex App (over local network). If I restart the App I am greeted with a black screen and nothing is happening. I tested this with the newest Version of Plexamp vor Windows and iOS.
almost certainly one of the items described in this article is happening ~ https://support.plex.tv/articles/plexamp-network-connectivity-tips/
Thanks for your reply. I checked the Network Settings of Plex and Require Secure Connections is set to “Preferred”. I have no problems connecting with the regular Plex App or do they have different requirements?
they do, yes.
can you share plexamp logs? i’m a bit confused also by the “black screen”, you should at least see an error message.
Sure, where can I find them?
on android: Settings > Advanced > Debugging
on Windows, somewhere on the filesystem in app data Plexamp.log
Dec 07, 2020 07:32:38.244 [Javascript] INFO - METRICS: Initializing.
Dec 07, 2020 07:32:38.245 [Javascript] INFO - USER: Refreshing users.
Dec 07, 2020 07:32:38.246 [Javascript] INFO - DEVICE: Loaded 5 devices.
Dec 07, 2020 07:32:38.250 [Javascript] INFO - DEVICE: Initializing manager.
Dec 07, 2020 07:32:38.250 [Javascript] INFO - DEVICE: Fetching latest provider list from cloud.
Dec 07, 2020 07:32:38.251 [Javascript] INFO - DEVICE: Fetching latest list from cloud.
Dec 07, 2020 07:32:38.252 [Javascript] INFO - DEVICE: Fetching latest cloud player list from https://sonos.plex.tv
Dec 07, 2020 07:32:38.252 [Javascript] INFO - DEVICE: Starting connection test.
Dec 07, 2020 07:32:38.323 [Javascript] INFO - DEVICE: Looking for an active server in 1 total servers.
Dec 07, 2020 07:32:38.324 [Javascript] INFO - DEVICE: Finding best connection for *SERVERNAME* *TOKEN*
Dec 07, 2020 07:32:38.327 [Javascript] INFO - HTTP: Issuing request to https://*IP*.*TOKEN*.plex.direct:32400/
Dec 07, 2020 07:32:38.328 [Javascript] INFO - HTTP: Issuing request to https://*IP*.*TOKEN*.plex.direct:32400/
Dec 07, 2020 07:32:38.329 [Javascript] INFO - HTTP: Issuing request to https://*IP*.*TOKEN*.plex.direct:32400/
Dec 07, 2020 07:32:38.363 [Javascript] INFO - ACCOUNT: Refreshing data.
Dec 07, 2020 07:32:38.375 [Javascript] WARNING - DEVICE: Server connection https://*IP*.*TOKEN*.plex.direct:32400 didn't work for *SERVERNAME*: getaddrinfo ENOTFOUND *IP*.*TOKEN*.plex.direct
Dec 07, 2020 07:32:38.576 [Javascript] INFO - METRICS: Saving latest cloud settings for metrics.
Dec 07, 2020 07:32:38.579 [Javascript] INFO - METRICS: Error loading from storage. Unexpected token u in JSON at position 0
Dec 07, 2020 07:32:38.579 [Javascript] INFO - METRICS: Loaded 0 events from storage.
Dec 07, 2020 07:32:38.633 [Javascript] INFO - USER: Loaded 3 users
Dec 07, 2020 07:32:38.693 [Javascript] INFO - DEVICE: Fetched 5 devices from the cloud.
Dec 07, 2020 07:32:39.204 [Javascript] WARNING - DEVICE: Error loading cloud players from plex.tv Request failed with status code 403
That would seem to imply the first thing in https://support.plex.tv/articles/plexamp-network-connectivity-tips/
I reinstalled the app and tried again:
Dec 07, 2020 07:55:51.505 [Javascript] INFO - METRICS: Initializing.
Dec 07, 2020 07:55:51.506 [Javascript] INFO - USER: Refreshing users.
Dec 07, 2020 07:55:51.508 [Javascript] INFO - DEVICE: Loaded 0 devices.
Dec 07, 2020 07:55:51.508 [Javascript] WARNING - METRICS: Cannot start up, no token.
Dec 07, 2020 07:55:51.508 [Javascript] INFO - USER: Loaded 0 users
Dec 07, 2020 07:55:51.508 [Javascript] WARNING - DEVICE: Cannot initialize, no token.
Dec 07, 2020 07:55:51.508 [Javascript] INFO - App: Device manager initialized in 2ms.
Dec 07, 2020 07:55:51.512 [Javascript] INFO - Sync: Loaded in 3ms.
Dec 07, 2020 07:55:51.512 [Javascript] INFO - Sync: Refreshing all items.
Dec 07, 2020 07:55:51.512 [Javascript] INFO - ACCOUNT: Refreshing data.
Dec 07, 2020 07:55:51.525 [Javascript] INFO - LRUCache: Loading 0 entries into Images cache.
Dec 07, 2020 07:55:51.525 [Javascript] INFO - LRUCache: Loading 0 entries into Palette cache.
Dec 07, 2020 07:55:51.526 [Javascript] INFO - LRUCache: Loading 0 entries into Loudness cache.
Dec 07, 2020 07:55:51.526 [Javascript] INFO - App: Settings, offline and cache initialized in 17ms.
Dec 07, 2020 07:55:51.526 [Javascript] INFO - Audio: Initializing.
Dec 07, 2020 07:55:51.526 [Javascript] INFO - Audio: Binding settings.
Dec 07, 2020 07:55:51.527 [Javascript] INFO - Audio: Setting player info.
Dec 07, 2020 07:55:51.529 [0x000064a0] DEBUG - BASS: Starting up.
Dec 07, 2020 07:55:51.548 [0x000064a0] INFO - BASS: Device 1: Default - enabled default - sample rates:
Dec 07, 2020 07:55:51.548 [0x000064a0] INFO - BASS: Device 2: Lautsprecher (Conexant SmartAudio HD) - enabled default handset hdmi headset line speakers - sample rates:
Dec 07, 2020 07:55:51.548 [0x000064a0] DEBUG - BASS: Using plugin path '*PATH*'.
Dec 07, 2020 07:55:51.586 [0x000064a0] INFO - BASS: Loaded ALAC plug-in version 2.4.0.0
Dec 07, 2020 07:55:51.612 [0x000064a0] INFO - BASS: Loaded FLAC plug-in version 2.4.4.2
Dec 07, 2020 07:55:51.637 [0x000064a0] INFO - BASS: Loaded OPUS plug-in version 2.4.1.12
Dec 07, 2020 07:55:51.661 [0x000064a0] INFO - BASS: Loaded APE plug-in version 2.4.2.0
Dec 07, 2020 07:55:51.687 [0x000064a0] INFO - BASS: Loaded MPC plug-in version 2.4.1.2
Dec 07, 2020 07:55:51.721 [0x000064a0] INFO - BASS: Loaded DSD plug-in version 2.4.1.2
Dec 07, 2020 07:55:51.721 [0x000064a0] INFO - BASS: Core version 2.4.15.0
Dec 07, 2020 07:55:51.721 [0x000064a0] INFO - BASS: Mixer version 2.4.9.0
Dec 07, 2020 07:55:51.721 [0x000064a0] INFO - BASS: FX version 2.4.12.1
Dec 07, 2020 07:55:51.721 [0x000064a0] INFO - BASS: Curl version is 7.64.1-DEV (protocols: dict file ftp ftps gopher http https imap imaps ldap ldaps pop3 pop3s rtsp smb smbs smtp smtps telnet tftp; ssl: OpenSSL/1.1.0j; libz: 1.2.11).
Dec 07, 2020 07:55:51.727 [Javascript] INFO - App: Player initialized in 201ms.
Dec 07, 2020 07:55:51.732 [Javascript] INFO - Player: Initializing with state null
Dec 07, 2020 07:55:51.733 [Javascript] INFO - App: Stopping activity recognition.
Dec 07, 2020 07:55:51.734 [Javascript] INFO - Player: Sending state changed [A]  -  (0/0) in state stopped with artwork false.
Dec 07, 2020 07:55:51.735 [Javascript] INFO - Network changed: type is unknown effectiveType is 4g -> 2
Dec 07, 2020 07:55:51.735 [Javascript] INFO - Discovery: Refresh based on network coming online.
Dec 07, 2020 07:55:51.736 [Javascript] INFO - Sync: New network type 2
Dec 07, 2020 07:55:51.736 [0x000064a0] INFO - BASS: Network switched to 2.
Dec 07, 2020 07:55:51.746 [Javascript] INFO - ViewState: Error loading from storage. Unexpected token u in JSON at position 0
Dec 07, 2020 07:55:51.756 [Javascript] INFO - Cloud: Loading from storage 0 items and 0 deleted.
Dec 07, 2020 07:55:51.757 [Javascript] INFO - App: Stores initialized in 30ms.
Dec 07, 2020 07:55:51.758 [Javascript] INFO - Shortcuts: Initializing!
Dec 07, 2020 07:55:51.759 [Javascript] INFO - Init: Stores all initialized.
Dec 07, 2020 07:55:51.759 [Javascript] INFO - App: Boot complete in 276ms.
Dec 07, 2020 07:55:51.910 [Javascript] WARNING - Animated: `useNativeDriver` is not supported because the native animated module is missing. Falling back to JS-based animation. To resolve this, add `RCTAnimation` module to this app, or remove `useNativeDriver`. More info: https://github.com/facebook/react-native/issues/11094#issuecomment-263240420
Dec 07, 2020 07:55:53.630 [Javascript] INFO - Auth: Requesting PIN.
Dec 07, 2020 07:55:53.867 [Javascript] INFO - Auth: Got PIN response.
Dec 07, 2020 07:55:56.738 [Javascript] INFO - Sync: Looking for incomplete items.
Dec 07, 2020 07:55:57.010 [Javascript] INFO - ACCOUNT: Refreshing data.
Dec 07, 2020 07:55:57.401 [Javascript] INFO - Auth: Done polling.
Dec 07, 2020 07:55:57.401 [Javascript] INFO - DEVICE: Persisting devices.
Dec 07, 2020 07:55:57.406 [Javascript] INFO - DEVICE: Loaded 0 devices.
Dec 07, 2020 07:55:57.406 [Javascript] INFO - DEVICE: Initializing manager.
Dec 07, 2020 07:55:57.407 [Javascript] INFO - DEVICE: Fetching latest provider list from cloud.
Dec 07, 2020 07:55:57.408 [Javascript] INFO - DEVICE: Fetching latest list from cloud.
Dec 07, 2020 07:55:57.408 [Javascript] INFO - DEVICE: Fetching latest cloud player list from https://sonos.plex.tv
Dec 07, 2020 07:55:57.408 [Javascript] INFO - DEVICE: No previous data, waiting for cloud data.
Dec 07, 2020 07:55:57.613 [Javascript] INFO - DEVICE: Fetched 6 devices from the cloud.
Dec 07, 2020 07:56:00.316 [Javascript] WARNING - DEVICE: Error loading cloud players from plex.tv Request failed with status code 403
Dec 07, 2020 07:56:00.319 [Javascript] INFO - DEVICE: Persisting devices.
Dec 07, 2020 07:56:00.320 [Javascript] INFO - DEVICE: Starting connection test.
Dec 07, 2020 07:56:00.320 [Javascript] INFO - DEVICE: Looking for an active server in 1 total servers.
Dec 07, 2020 07:56:00.320 [Javascript] INFO - DEVICE: Finding best connection for *SERVERNAME* *TOKEN*.
Dec 07, 2020 07:56:00.321 [Javascript] INFO - HTTP: Issuing request to https://*IP*.*TOKEN*.plex.direct:32400/
Dec 07, 2020 07:56:00.322 [Javascript] INFO - HTTP: Issuing request to https://*IP*.*TOKEN*.plex.direct:32400/
Dec 07, 2020 07:56:00.433 [Javascript] WARNING - DEVICE: Server connection https://*IP*.*TOKEN*.plex.direct:32400 didn't work for *SERVERNAME*: getaddrinfo ENOTFOUND *IP*.*TOKEN*.plex.direct
Dec 07, 2020 07:56:01.736 [Javascript] INFO - Player: Precaching next 15 tracks.
Dec 07, 2020 07:56:15.325 [Javascript] WARNING - DEVICE: Server connection https://*IP*.*TOKEN*.plex.direct:32400 didn't work for *SERVERNAME*: timeout of 15000ms exceeded
Dec 07, 2020 07:56:15.327 [Javascript] WARNING - DEVICE: Server connection https://*IP*.*TOKEN*.plex.direct:32400 didn't work for *SERVERNAME*: timeout of 15000ms exceeded
Dec 07, 2020 07:56:15.328 [Javascript] INFO - DEVICE: Checking *SERVERNAME* for local HTTP connection.
Dec 07, 2020 07:56:15.328 [Javascript] INFO - HTTP: Issuing request to http://*IP*:32400/identity
Dec 07, 2020 07:56:15.329 [Javascript] INFO - HTTP: Issuing request to http://*LOCAL IP*:32400/identity
Dec 07, 2020 07:56:25.331 [Javascript] WARNING - DEVICE: Connection testing failed for *SERVERNAME*
I tried the last URL (http://LOCAL IP:32400/identity) in my Browser and I got the following response:
<MediaContainer size="0" claimed="1" machineIdentifier="*UUID*" version="1.21.0.3711-b509cc236"> </MediaContainer>
please read the link i posted. all of those things must be true on your network.
I have read it. It says:
Note that the apps will only have trouble connecting if all of the above holds true. Changing any one of these items should allow successful connections.
and because I have set “Require Secure Connections” to “Preferred”, I thought it should work.
yeah, agreed.
it’s hard to see what it’s trying from the logs, can you DM them to me unredacted, along with the IP of your device? any VPNs involved or anything else weird?
I figured it out. I had to set Preferred network interface to a specific one instead of using all.
Thanks for the update! Just so you know, plexamp works fine with HTTPS on LAN, you just need to make sure our DNS is working, per those tips.
