Can't connect
I upgraded my ATV2 to the latest version over the weekend. Then I set up Plexconnect. It was all working great until tonight when I tried to watch something. All I see on my ATV is an option for computers and settings. I did not change anything on my network and it was worked fine for the last 2 days. I tried a restart and a reset and putting all the settings back in, but still get this same screen.
I checked online and I have read many different options to fix but no luck. Anyone else seeing this??
Learn to read.
<span style="color:rgb(102,102,102);"><a data-ipb='nomediaparse'  class="" href='http://forums.plexapp.com/index.php/topic/69410-read-before-posting/' title="READ BEFORE POSTING - started  27 May 2013 - 12:00 PM">READ BEFORE POSTING</a>&nbsp;<--- STICKY</span>
 How to report an issue (do not private message asking for support or features!): click here
Try rebooting your router/make sure you are online.
Learn to read… I fell bad that you are so unhappy. It must be miserable to be you… Here’s hoping you have a happier day tomorrow:)
I'm not sure about the ATV2, but my AT3 was upgraded in the weekend and did the same after about a day of use. I reloaded the certificate back into it ( though the profile was still there), and it is working ok
So the only thing I have found that works is going to my PMS and running “sudo ./PlexConnect.py” again. Then my atv2 starts working great. As far as I can tell no settings change, DNS remains the same. But for whatever reason I’m all good after that. Problem is I seem to have to do this every couple of days.
Still, the last couple of pages of the Log (before restarting) would be fine...
