I’m amazed at how common and old this problem is?! It seems it’s been around for years now with many Plex Pass members complaining and no real solution at hand!
I dare to hope that by now this has finally been resolved…how does one go about it?
As many have mentioned, I have labels with no content and no way to remove them?!
Thanks,
I’ve recently run into this too – it appears this can happen under some circumstances.
There’s a manual fix described in this thread:
short version:
- Execute the
Plex SQLiteapp (in the app folder) in the command prompt (power shell, terminal…) - enter
.open "<path to database>", pointing to the thecom.plexapp.plugins.library.dbfile in the server data directory (->Library>Plex Media Server>Plug-in Support>Databases) - enter
Delete from Tags where Tags.tag="<name of the tag>" and Tags.tag_type=11;and pressreturn - reload the web app to verify the tag is gone
- exit the command shell app by entering
.exitand pressingreturn
Thanks for the reply but…WOW, this is just ridiculous!?
One has to be a computer engineer to be able to simply delete…an unused label!!?
This is crazy stupid and unbelievable it hasn’t been resolved yet after so many years!
I have my PMS on a QNAP NAS so I only use the Web App therefore I can’t even apply this solution - assuming I even knew how!
So the lesson here is to NOT use labels then…just great
