Cant enable some channels
Server Version#: 1.24.4.5081
Player Version#: 4.63.0
Tuner Make/Model: HDHomeRun PRIME
Guide/Lineup name: Midcontinent Communications (393 channels)
Using XMLTV?: no
Channel number/Name: 119, 125, 168, 190, 304, 309, 590 (missing), 591, 604, 609, 665 (missing), 857
All channels except 590 & 665 which are missing from EPG; the rest are listed in EPG but when you set the channel it will not save.
For example 119, if i enable and click the channel 119 on the right, it switched automatically to 030, the STD version of the channel and when you click save, it doesnt do anything. That happens when you connect directly to the IP of the web UI.
If you connect to the server via plex.tv, then you can set the correct channel, but if you try to save it, the save button spins for a second and doesnt actually save anything just like when you connect directly to the web ui.
If I delete the DVR and reset it up and try to enable those channels during setup, I will get an error says there was a problem trying to save.
Is anyone taking a look at this? I’m still having the same issues.
