Channel Mapping does not save
Server Version#: (4.50.1) 1.21.1.3876
Player Version#: latest Public Channel
Tuner Make/Model: NVidia Shield
Guide/Lineup name: OTA
Using XMLTV?: No
Channel number/Name: All of them
<If providing server logs, please do NOT turn on verbose logging>
Tuner Make/Model: HD HomeRun [HDHomeRun CONNECT QUATRO] [HDHomeRun CONNECT QUATRO] [HDHomeRun CONNECT]
Signal type: Antenna
Language: English
I have removed my HD HomeRun configured DVRs from the listing as instructed, and when I have attempted to add them back, they will not properly show. The process of finding the channels goes through, and even sometimes, the EPG will build. Whenever you tune to a channel, it will state it cannot find the requested channel. I go back into the webserver configurations and see that the DVRs Manage Channels are zeroed out. All mappings of channels are erased, and manually setting them again does not save.
Logs if that helps: Microsoft OneDrive
Bump
Not sure if related but i have 1.21.1.3876 running on a linux box with a hauppageQuadHD and after i did a new scan i lost the NBC affiliate. It doesn’t do this on Kaffeine when i watch the tuner through that i can see the channel.
I can see all channels and the only source of Live TV through the HDHomeRun App on my FireCube and Nvidia Shield. I am pretty sure it is something to do with the xml for channels, but I do not know where to find that or to get a custom one for testing.
I had to remove my plexdata rename my server and statically assign the HDHomeRun devices for it to properly keep the settings. Now if I can get the actual various players to play the stream consistently.
