Server Version#: 1.28.2.6151
Player Version#: Web/Various
Tuner Make/Model: HDHomeRun Prime 3
Guide/Lineup name: Cox Communications
Using XMLTV?: Not sure
Channel number/Name: Affects a fixed subset of the channel list.
Someone’s previous post about this issue didn’t seem to go anywhere productive before it was closed, so starting a new thread.
For certain channels in my channel list (mainly QVC, a number of other local and On Demand), the Channel Matching dialog will not save and close on clicking “save” if any of this subset of channels is checked and selected with its EPG channel match. Channel matching and saving otherwise works fine. The only options are to revert the offending checked selections and save, or click either “cancel” or the “x” to close the dialog, resulting in no changes being saved. It IS possible to tune these channels outside of Plex, using the HDHomeRun native app, however nothing seems to work to solve this within Plex. If it’s possible, I’m willing to manually edit a configuration file somewhere to force the match.
Thanks everyone!
