Can't find audio settings?
I am having the same problems finding the audio settings other than the audio language. I do not have a Plex Pass; I’m waiting to solve several problems. I’m using Windows 10, current. Player appears in a web app in Firefox, also the latest version.
– I have downloaded the latest Plex Player whenever the Player Web app tells me to, and PMP updates itself. I am current now, but I still do not see the TV mode icon that appears in the screenshot above. (Seems odd that general audio settings are under TV mode, but I don’t really care if I can somehow find them.)
– I can only get into full screen mode when a movie is playing, through the outward-pointing diagonal arrows icon at the top right. There are no other options there except to select a player (for Plex Pass users only).
– I cannot find the usual app “About” menu option which would allow me to confirm what version of the web app I’m running, but the update notifications and “success” pop-up say that I’m in the current version.
So, can I get to the audio settings somehow? Or if I can’t see the TV Mode option, there’s no other way? Should I download an app from the Google Play story? A comment above says that app is an old one.
If there’s a way, I would appreciate a sequence: Windowed home screen/where to click next and what I’ll see/Settings/Audio Preferences (or whatever it’s called).
Thanks.
It look like the new Windows app has no audio settings, and no TV mode.
Then no way to use my 5.1 devices. How is that even possible ???
Do I Have to go back to the old plex home theater which did that perfectly ?
The New app is a bit limited.
I suggest using Plex Media Player instead: (It’s only available in the forum)
or
re 5.1 - I couldn’t find it in the desktop version hence coming here to find out about PMP and TV mode.
What do we do after the end of Jan if we want to use an external surround card ??
Eventually PMP will stop working with server upgrades etc …
I can’t find it either. Not in Windows or in Full Screen mode. At least not a general audio setting. I can find the one next to each video I select. I like Plex’s clean interface, but the audio is too well hidden. Mine won’t stop making this static or popping noise. It sounds like a corrupted file or something but Plex does it on all my videos.
This started about a week ago, before that it was fine.
Any idea how to fix?
Thank you for considering this question.
I wasn’t able to find an AUDIO->SETTINGS function anywhere in the PMP UI. And yes, I have tried the “trick” of placing Plex Media Player in full-screen mode. If anyone has a way to do this inside the PMP, please share it!
In the meantime, I have a work-around for Windows 10 users:
Follow this process to redirect audio from PMP away from the “default” Windows output device, to a specific Windows output device:
  1. Start PMP playing anything (Plex must already be playing something or it won’t be visible as an option!)
  2. Right click the “sound” icon on the taskbar
  3. Select “Open Sound Settings”
  4. Select “Advanced Sound Options”
  5. Choose the output you prefer under “output” to the right of the PlexMediaPlayer item
Example shown here:
For reference, my setup:
  • Version: Plex Media Player Version 3.104.2
  • OS: Windows 10 Pro V1903/B18362.657
  • Behringer XR18 Digital Mixer (18x18 USB I/O for Windows)
Not “Fullscreen”, but “TV Mode”.
pmp_fullscreen
Thanks! That does the trick! :smiley:
For reference, the on-screen selection entitled “Device Autoselect device” doesn’t respond to mouse clicks, you have to use press “enter” on the keyboard, then it displays options:
Now if we can just convince the Plex crew to make this menu visible in the ACTUAL settings area! I mean.. sheesh!! :person_facepalming:
This feature is so hidden away it is stupid, seems like no thought has gone into it all or we all wouldn’t be googling how to find the fuggin setting.
Well, as the meme says…
So, with the new player that Plex has been “encouraging” (threatening?) us with for a couple weeks, the ability to change the audio is once again missing. :frowning:
Anyone with ideas on how to get to the audio settings now with the “improved” interface..?
Install Plex Media Player
Any word on getting access to audio settings on windows? I don’t see a TV layout option on the interface.
This DOES NOT WORK on the mac version. I just downloaded the Plex Media Player (I’ll provide screenshots, heck I’ll even provide a video) and it takes you to the exact same version that’s on the Plex “App” for mac, that you get from the Plex downloads area. Made a short little video to show you how and why it doesn’t work. I thought I got a break for second in the video, but nope, still doesn’t work, you’ll see what I’m talking about when you watch it.
  1. the recommendation from above is no longer valid, since Plex player now has support for bitstreaming.
  2. in your video, you went to the settings, but failed to click on the ‘Player’ menu item on the left side
  3. Plex Media Player in “TV mode” provides the settings menu underneath the top item on the left sidebar (under your avatar picture)
