and… it just worked. must have been on the podcast provider’s end…
Thanks! =)
Thanks! =)
I cannot get any URLs from Danish National Radio (DR) to work in my Android App (s9). It keeps telling me “Something went wrong. Make sure the URL is correct and try again.”
like this one:
http://www.dr.dk/mu/Feed/recept-radio.xml?format=podcast
find more here: https://www.dr.dk/allepodcast/?letter=
I would be even more neat, if I could search and find DR podcasts using the search functionality in the app/web interface.
I hope you will look at this issue (“something went wrong…”) and this funtionality (Search and find DR padcast within)
I find I can add Podcast URLs, but I have to submit the URL twice and sometimes even three times before Plex will recognise it and add it to my Podcasts.
So it does work, albeit annoyingly.
Apologies if someone has already mentioned this.
Tried with several urls, different podcasts from different sources, adding it via the web interface and the iOS app, never worked.
I can’t get the RSS feed from SimpleCast to work, either.
Example here: https://feeds.simplecast.com/fah7Xqrw
This one isn’t working https://www.defenseone.com/topic/podcasts/
This one does not work in Plex, while ok in Overcast/Apple/etc
https://www.ximalaya.com/album/11662130.xml
This one is partially working. It shows episodes, but none after 30.11.2018.
https://blog.ct.de/ctuplink/ctuplinkvideohd.rss
Still can’t get it working → https://www.ximalaya.com/album/11662130.xml
