Cant manually install PlexMediaServer 418
I just got my Nas synology 418 and tried to manually install plex server and kept getting the following error: this package is not supported on the platform of DiskStation or is incompatible with the current DSM version.
Model: DS418
DSM version: DSM 6.2-23739 Update 2
PSM version: PlexMediaServer-1.13.4.5271-200287a06-x86_64.spk
Please help and really apprecite the help
@liwan
Come on over to the Alpha test. Give it a good test drive and give some feedback (that’s all I ask).
I’m trying to make it ready for everyone
Yes I am interested to do Alpha testing. How I get the package or installation?
Yes found it and it works … will start my Alpha testing
:frowning:
why so mean? :stuck_out_tongue:
lol
So far everything went well. I just need to figure out how to name the tv series since they dont show up as series but showed as duplicates (12 copies of number 1). Also some folders are not scanned properly (most likely the naming issues) and need to figure out on how to force the scanning.
You guys are AWESOME! super quick response
Thank you!
This will require a lot of work at nite after work :wink:
It is trivial if you get FileBot (the defacto best tool for the job) . :smiley:
You can also try FreeCommanderXE to rename files in bulk.
Thank you guys for all the supports and tools.
I was able to change all the naming and Plex has updated to the right structure and numbering :slight_smile:
Happy camper here
