Can't Play With Android and Android TV
Plex Media Server - Copie.log (10.0 KB)
Server Version#: 1.23.5.4862
Player Version#: 8.20.1.26670
Hi !
I got an issue with Android and Android TV (only on remote). I can’t play video, and whatever I do (disable automatic quality), i got an error “Cant Play video” (in french for me).
Really strange behavior, if I use VLC as alternative video player, it’s working
I don’t think error is due to server, because I can read it from Android TV and Android (local).
I got this error for a long time and I don’t know what to do.
Help appreciated, thanks
Is this for downloaded content or playing via remote access?
If it’s the latter, can you check the quality settings used for streaming?
would be good to get the android logs from the device as well
Please include the full ZIP file from your server. The edited file you attached contains limited information.
Jul 30, 2021 14:49:47.492 [0x7fee0ffe8b38] DEBUG - [Transcode] MDE: Blood Machines (2020): selected subtitle cannot be converted to a compatible format, burning into video stream
Try playing the video without subtitles.
