Can't reach Plex server from work. (worked fine yesterday)
My workplace has a very restrictive firewall, but I was able to access Plex through the relay. It let me stream music using the browser through app.plex.tv (Plexamp also worked until today). Today I am not able to connect through my work internet at all.
I am able to directly connect using my phone through cellular network, so my server isn’t dead. Did something change with the relay since yesterday?
Plex had an outage earlier. Details available at https://status.plex.tv/.
Shouldn’t it be back up again now though? I can’t use the relay at all.
Yes, it should all be fixed now. Have you tried restarting your PMS?
No. I have to get home from work first to be able to do that. I can try, and then we’ll see if it works again tomorrow, I guess. :slight_smile:
Restarting the server seems to have helped. :slight_smile:
