Can't reach PMS on Synology 916+
this is all lan for me too. 172.31.100.x space.
static on Synology. AppleTV is DHCP. Mac is DHCP. Windows VM is static. All had issues with accessing the PMS. However I could still connect to 32400 on command line… just nothing came back.
DNS is using Synology router… which is pointing to OpenDNS resolvers.
Synology showed the process running. Restarted it was no help. Upgrade from 1.18.1 to 1.18.2 didn’t solve it. Issue started on the 1.18.1 upgrade.
And issue seemed to trigger on loss of network in the logs.
This is my logs when it started.
Nov 13, 2019 02:10:52.651 [0x7f86bef41700] DEBUG - Butler: refreshed 80 items
Nov 13, 2019 02:28:56.785 [0x7f8647735700] DEBUG - Sync: uploadStatus
Nov 13, 2019 02:40:53.370 [0x7f86665a1700] DEBUG - Putting plug-in com.plexapp.agents.localmedia to sleep.
Nov 13, 2019 02:40:53.370 [0x7f86665a1700] DEBUG - Stopping [com.plexapp.agents.localmedia].
Nov 13, 2019 02:40:53.370 [0x7f86665a1700] DEBUG - [com.plexapp.agents.localmedia] Killing.
Nov 13, 2019 02:40:53.375 [0x7f86cd3f5700] WARN - JobManager: Could not find job for handle 29967
Nov 13, 2019 02:41:03.371 [0x7f86665a1700] DEBUG - Stopping file watcher for com.plexapp.agents.localmedia
Nov 13, 2019 02:45:02.119 [0x7f86436fc700] DEBUG - Butler: Starting delayed task RefreshPeriodicMetadata.
Nov 13, 2019 02:45:52.682 [0x7f86bef41700] DEBUG - Butler: refreshed 0 artists
Nov 13, 2019 02:58:56.785 [0x7f86436fc700] DEBUG - Sync: uploadStatus
Nov 13, 2019 03:09:02.119 [0x7f8647735700] DEBUG - Butler: Starting delayed task ReverseGeocode.
Nov 13, 2019 03:09:52.710 [0x7f86bef41700] DEBUG - The butler processed 0 files for reverse geocoding
Nov 13, 2019 03:28:56.786 [0x7f866511f700] DEBUG - Sync: uploadStatus
Nov 13, 2019 03:58:56.786 [0x7f8664855700] DEBUG - Sync: uploadStatus
Nov 13, 2019 04:02:55.538 [0x7f86cce19700] DEBUG - EventSource: Failure in ReadData (2 - End of file).
Nov 13, 2019 04:02:55.584 [0x7f86cce19700] DEBUG - MyPlex: We appear to have lost Internet connectivity, resetting device URL cache.
Nov 13, 2019 04:02:55.584 [0x7f86cce19700] ERROR - EventSource: Retrying in 15 seconds.
Nov 13, 2019 04:03:10.584 [0x7f86ccb2b700] DEBUG - EventSource: Resolving 184.105.148.116 port 443
Nov 13, 2019 04:03:10.584 [0x7f86ccb2b700] DEBUG - EventSource: Resolved 184.105.148.116 to 184.105.148.116
Nov 13, 2019 04:03:11.763 [0x7f86cce19700] DEBUG - EventSource: Connected in 1150 ms.
Nov 13, 2019 04:03:11.763 [0x7f86cce19700] DEBUG - EventSource: Wrote data, reading reply.
Nov 13, 2019 04:03:20.449 [0x7f86ccb2b700] DEBUG - EventSource: Read HTTP reply header.
Nov 13, 2019 04:03:20.449 [0x7f86ccb2b700] DEBUG - MyPlex: We appear to have regained Internet connectivity.
Nov 13, 2019 04:03:20.454 [0x7f86ccb2b700] DEBUG - EventSource: Successfully connected to 184.105.148.116.
Nov 13, 2019 04:20:13.384 [0x7f86cce19700] DEBUG - EventSource: Failure in ReadData (2 - End of file).
Nov 13, 2019 04:20:13.384 [0x7f86cce19700] DEBUG - MyPlex: We appear to have lost Internet connectivity, resetting device URL cache.
Nov 13, 2019 04:20:13.384 [0x7f86cce19700] ERROR - EventSource: Retrying in 15 seconds.
Nov 13, 2019 04:20:28.384 [0x7f86ccb2b700] DEBUG - EventSource: Resolving 184.105.148.116 port 443
Nov 13, 2019 04:20:28.384 [0x7f86ccb2b700] DEBUG - EventSource: Resolved 184.105.148.116 to 184.105.148.116
Nov 13, 2019 04:20:28.412 [0x7f86cce19700] DEBUG - EventSource: Failure in Connect (111 - Connection refused).
Nov 13, 2019 04:20:28.412 [0x7f86cce19700] ERROR - EventSource: Retrying in 30 seconds.
Nov 13, 2019 04:20:58.412 [0x7f86ccb2b700] DEBUG - EventSource: Resolving 184.105.148.116 port 443
Nov 13, 2019 04:20:58.412 [0x7f86ccb2b700] DEBUG - EventSource: Resolved 184.105.148.116 to 184.105.148.116
Nov 13, 2019 04:20:58.443 [0x7f86cce19700] DEBUG - EventSource: Failure in Connect (111 - Connection refused).
Nov 13, 2019 04:21:03.442 [0x7f86cce19700] DEBUG - EventSource: Stopping.
Nov 13, 2019 04:21:03.442 [0x7f86cce19700] DEBUG - HTTP requesting GET https://plex.tv/services/pubsub/servers
Nov 13, 2019 04:21:08.976 [0x7f86cce19700] ERROR - Error issuing curl_easy_perform(handle): 52
Nov 13, 2019 04:21:08.976 [0x7f86cce19700] WARN - HTTP error requesting GET https://plex.tv/services/pubsub/servers (0, No error) (Empty reply from server)
Nov 13, 2019 04:21:13.978 [0x7f86cce19700] WARN - PubSubManager: Connection to 178.79.145.139 failed: Connection timed out.
Nov 13, 2019 04:21:13.978 [0x7f86cce19700] WARN - PubSubManager: Connection to 82.94.168.17 failed: Connection timed out.
Nov 13, 2019 04:21:13.978 [0x7f86cce19700] WARN - PubSubManager: Connection to 45.79.197.58 failed: Connection timed out.
Nov 13, 2019 04:21:13.978 [0x7f86cce19700] WARN - PubSubManager: Connection to 72.14.179.64 failed: Connection timed out.
Nov 13, 2019 04:21:13.978 [0x7f86cce19700] WARN - PubSubManager: Connection to 97.107.133.152 failed: Connection timed out.
Nov 13, 2019 04:21:13.978 [0x7f86cce19700] WARN - PubSubManager: Connection to 139.162.158.105 failed: Connection timed out.
Nov 13, 2019 04:21:13.978 [0x7f86cce19700] WARN - PubSubManager: Connection to 172.105.203.197 failed: Connection timed out.
Nov 13, 2019 04:21:13.978 [0x7f86cce19700] WARN - PubSubManager: Connection to 45.118.132.58 failed: Connection timed out.
Nov 13, 2019 04:21:13.978 [0x7f86cce19700] WARN - PubSubManager: Connection to 184.105.148.114 failed: Connection timed out.
Nov 13, 2019 04:21:13.978 [0x7f86cce19700] WARN - PubSubManager: Connection to 172.105.13.59 failed: Connection timed out.
Nov 13, 2019 04:21:13.978 [0x7f86cce19700] WARN - PubSubManager: Connection to 184.105.148.116 failed: Connection timed out.
Nov 13, 2019 04:21:13.979 [0x7f86cce19700] DEBUG - EventSource: Stopping.
Nov 13, 2019 04:21:13.990 [0x7f86cce19700] ERROR - EventSource: Retrying in 60 seconds.
Nov 13, 2019 04:21:17.298 [0x7f86ccb2b700] DEBUG - EventSource: Stopping.
Nov 13, 2019 04:22:13.990 [0x7f86ccb2b700] DEBUG - EventSource: Resolving 184.105.148.116 port 443
Nov 13, 2019 04:22:13.990 [0x7f86ccb2b700] DEBUG - EventSource: Resolved 184.105.148.116 to 184.105.148.116
Nov 13, 2019 04:22:14.018 [0x7f86cce19700] DEBUG - EventSource: Failure in Connect (111 - Connection refused).
Nov 13, 2019 04:22:19.017 [0x7f86cce19700] DEBUG - EventSource: Stopping.
Nov 13, 2019 04:22:24.018 [0x7f86cce19700] DEBUG - PubSubManager: Time to connect to 172.105.203.197 was 274 ms.
Nov 13, 2019 04:22:24.018 [0x7f86cce19700] WARN - PubSubManager: Connection to 82.94.168.17 failed: Connection timed out.
Nov 13, 2019 04:22:24.018 [0x7f86cce19700] WARN - PubSubManager: Connection to 45.56.116.228 failed: Connection timed out.
Nov 13, 2019 04:22:24.018 [0x7f86cce19700] WARN - PubSubManager: Connection to 72.14.179.64 failed: Connection timed out.
Nov 13, 2019 04:22:24.018 [0x7f86cce19700] WARN - PubSubManager: Connection to 45.79.128.184 failed: Connection timed out.
Nov 13, 2019 04:22:24.018 [0x7f86cce19700] WARN - PubSubManager: Connection to 172.104.245.130 failed: Connection timed out.
Nov 13, 2019 04:22:24.018 [0x7f86cce19700] WARN - PubSubManager: Connection to 178.79.145.139 failed: Connection timed out.
Nov 13, 2019 04:22:24.018 [0x7f86cce19700] WARN - PubSubManager: Connection to 45.118.132.58 failed: Connection timed out.
Nov 13, 2019 04:22:24.018 [0x7f86cce19700] WARN - PubSubManager: Connection to 184.105.148.116 failed: Connection timed out.
Nov 13, 2019 04:22:24.018 [0x7f86cce19700] WARN - PubSubManager: Connection to 172.105.99.32 failed: Connection timed out.
Nov 13, 2019 04:22:24.018 [0x7f86cce19700] WARN - PubSubManager: Current server (184.105.148.116) failed, we'll switch.
Nov 13, 2019 04:22:24.020 [0x7f86cce19700] DEBUG - EventSource: Stopping.
Nov 13, 2019 04:22:24.020 [0x7f86cce19700] DEBUG - EventSource: Resolving 172.105.203.197 port 443
Nov 13, 2019 04:22:24.020 [0x7f86cce19700] DEBUG - PubSubManager: Updating best host to 172.105.203.197.
Nov 13, 2019 04:22:24.020 [0x7f86cce19700] DEBUG - PubSubManager: Updating best ping time for 172.105.203.197 to 274 ms.
Nov 13, 2019 04:22:24.021 [0x7f86cce19700] DEBUG - EventSource: Stopping.
Nov 13, 2019 04:22:24.021 [0x7f86cce19700] DEBUG - EventSource: Resolved 172.105.203.197 to 172.105.203.197
Nov 13, 2019 04:22:27.441 [0x7f86ccb2b700] DEBUG - EventSource: Connected in 278 ms.
Nov 13, 2019 04:22:27.442 [0x7f86ccb2b700] DEBUG - EventSource: Wrote data, reading reply.
Nov 13, 2019 04:22:44.020 [0x7f86cce19700] DEBUG - EventSource: Failure in IdleTimeout (0 - Success).
Nov 13, 2019 04:22:44.020 [0x7f86cce19700] ERROR - EventSource: Retrying in 15 seconds.
Nov 13, 2019 04:22:59.020 [0x7f86ccb2b700] DEBUG - EventSource: Resolving 172.105.203.197 port 443
Nov 13, 2019 04:22:59.020 [0x7f86ccb2b700] DEBUG - EventSource: Resolved 172.105.203.197 to 172.105.203.197
Nov 13, 2019 04:23:16.210 [0x7f86cce19700] DEBUG - EventSource: Stopping.
Nov 13, 2019 04:23:16.210 [0x7f86ccb2b700] DEBUG - EventSource: Stopping.
Nov 13, 2019 04:23:19.020 [0x7f86cce19700] DEBUG - EventSource: Failure in IdleTimeout (0 - Success).
Nov 13, 2019 04:23:29.020 [0x7f86cce19700] WARN - PubSubManager: Connection to 82.94.168.19 failed: Connection timed out.
Nov 13, 2019 04:23:29.020 [0x7f86cce19700] WARN - PubSubManager: Connection to 45.79.197.58 failed: Connection timed out.
Nov 13, 2019 04:23:29.020 [0x7f86cce19700] WARN - PubSubManager: Connection to 45.79.23.169 failed: Connection timed out.
Nov 13, 2019 04:23:29.020 [0x7f86cce19700] WARN - PubSubManager: Connection to 45.79.128.184 failed: Connection timed out.
Nov 13, 2019 04:23:29.020 [0x7f86cce19700] WARN - PubSubManager: Connection to 139.162.158.105 failed: Connection timed out.
Nov 13, 2019 04:23:29.020 [0x7f86cce19700] WARN - PubSubManager: Connection to 139.162.120.52 failed: Connection timed out.
Nov 13, 2019 04:23:29.020 [0x7f86cce19700] WARN - PubSubManager: Connection to 178.79.145.139 failed: Connection timed out.
Nov 13, 2019 04:23:29.020 [0x7f86cce19700] WARN - PubSubManager: Connection to 139.162.57.189 failed: Connection timed out.
Nov 13, 2019 04:23:29.020 [0x7f86cce19700] WARN - PubSubManager: Connection to 184.105.148.116 failed: Connection timed out.
Nov 13, 2019 04:23:29.020 [0x7f86cce19700] WARN - PubSubManager: Connection to 172.105.13.59 failed: Connection timed out.
Nov 13, 2019 04:23:29.020 [0x7f86cce19700] WARN - PubSubManager: Connection to 172.105.203.197 failed: Connection timed out.
Nov 13, 2019 04:23:29.020 [0x7f86cce19700] DEBUG - EventSource: Stopping.
Nov 13, 2019 04:23:29.021 [0x7f86cce19700] DEBUG - EventSource: Stopping.
Nov 13, 2019 04:23:29.021 [0x7f86cce19700] ERROR - EventSource: Retrying in 30 seconds.
Nov 13, 2019 04:23:56.002 [0x7f86ccb2b700] DEBUG - EventSource: Stopping.
Nov 13, 2019 04:23:59.021 [0x7f86cce19700] DEBUG - EventSource: Resolving 172.105.203.197 port 443
Nov 13, 2019 04:23:59.021 [0x7f86cce19700] DEBUG - EventSource: Resolved 172.105.203.197 to 172.105.203.197
Nov 13, 2019 04:24:19.021 [0x7f86ccb2b700] DEBUG - EventSource: Failure in IdleTimeout (0 - Success).
Nov 13, 2019 04:24:20.774 [0x7f86ccb2b700] DEBUG - EventSource: Stopping.
Nov 13, 2019 04:24:20.775 [0x7f86ccb2b700] DEBUG - PubsubServerManager: Switching to next host in region: 139.162.120.52
Nov 13, 2019 04:24:20.776 [0x7f86ccb2b700] DEBUG - EventSource: Stopping.
Nov 13, 2019 04:24:20.776 [0x7f86ccb2b700] DEBUG - EventSource: Resolving 139.162.120.52 port 443
Nov 13, 2019 04:24:20.776 [0x7f86ccb2b700] DEBUG - EventSource: Resolved 139.162.120.52 to 139.162.120.52
Nov 13, 2019 04:24:26.226 [0x7f86cce19700] DEBUG - EventSource: Stopping.
Nov 13, 2019 04:24:26.226 [0x7f86ccb2b700] DEBUG - EventSource: Stopping.
Nov 13, 2019 04:24:27.534 [0x7f86ccb2b700] DEBUG - EventSource: Stopping.
Nov 13, 2019 04:24:40.776 [0x7f86cce19700] DEBUG - EventSource: Failure in IdleTimeout (0 - Success).
Nov 13, 2019 04:24:40.776 [0x7f86cce19700] ERROR - EventSource: Retrying in 15 seconds.
Nov 13, 2019 04:24:55.776 [0x7f86ccb2b700] DEBUG - EventSource: Resolving 139.162.120.52 port 443
Nov 13, 2019 04:24:55.776 [0x7f86ccb2b700] DEBUG - EventSource: Resolved 139.162.120.52 to 139.162.120.52
Nov 13, 2019 04:25:15.776 [0x7f86cce19700] DEBUG - EventSource: Failure in IdleTimeout (0 - Success).
Nov 13, 2019 04:25:23.225 [0x7f86ccb2b700] DEBUG - EventSource: Stopping.
Nov 13, 2019 04:25:25.776 [0x7f86cce19700] DEBUG - PubSubManager: Time to connect to 45.79.128.184 was 467 ms.
Nov 13, 2019 04:25:25.776 [0x7f86cce19700] DEBUG - PubSubManager: Time to connect to 184.105.148.116 was 515 ms.
Nov 13, 2019 04:25:25.776 [0x7f86cce19700] DEBUG - PubSubManager: Time to connect to 45.79.197.58 was 526 ms.
Nov 13, 2019 04:25:25.776 [0x7f86cce19700] WARN - PubSubManager: Connection to 82.94.168.19 failed: Connection timed out.
Nov 13, 2019 04:25:25.776 [0x7f86cce19700] WARN - PubSubManager: Connection to 45.79.23.169 failed: Connection timed out.
Nov 13, 2019 04:25:25.776 [0x7f86cce19700] WARN - PubSubManager: Connection to 172.104.245.130 failed: Connection timed out.
Nov 13, 2019 04:25:25.776 [0x7f86cce19700] WARN - PubSubManager: Connection to 139.162.120.52 failed: Connection timed out.
Nov 13, 2019 04:25:25.776 [0x7f86cce19700] WARN - PubSubManager: Connection to 178.79.165.194 failed: Connection timed out.
Nov 13, 2019 04:25:25.776 [0x7f86cce19700] WARN - PubSubManager: Connection to 139.162.57.189 failed: Connection timed out.
Nov 13, 2019 04:25:25.776 [0x7f86cce19700] WARN - PubSubManager: Connection to 172.105.13.59 failed: Connection timed out.
Nov 13, 2019 04:25:25.776 [0x7f86cce19700] WARN - PubSubManager: Current server (139.162.120.52) failed, we'll switch.
Nov 13, 2019 04:25:25.777 [0x7f86cce19700] DEBUG - EventSource: Stopping.
Nov 13, 2019 04:25:25.777 [0x7f86cce19700] DEBUG - EventSource: Resolving 45.79.128.184 port 443
Nov 13, 2019 04:25:25.778 [0x7f86cce19700] DEBUG - PubSubManager: Updating best host to 45.79.128.184.
Nov 13, 2019 04:25:25.778 [0x7f86ccb2b700] DEBUG - EventSource: Resolved 45.79.128.184 to 45.79.128.184
Nov 13, 2019 04:25:25.778 [0x7f86cce19700] DEBUG - PubSubManager: Updating best ping time for 45.79.128.184 to 467 ms.
Nov 13, 2019 04:25:25.778 [0x7f86cce19700] DEBUG - EventSource: Stopping.
Nov 13, 2019 04:25:26.258 [0x7f86cce19700] DEBUG - EventSource: Stopping.
Nov 13, 2019 04:25:26.398 [0x7f86cce19700] DEBUG - EventSource: Connected in 524 ms.
Nov 13, 2019 04:25:26.398 [0x7f86cce19700] DEBUG - EventSource: Wrote data, reading reply.
Nov 13, 2019 04:25:28.648 [0x7f86ccb2b700] DEBUG - EventSource: Stopping.
Nov 13, 2019 04:25:28.659 [0x7f86cce19700] DEBUG - EventSource: Stopping.
Nov 13, 2019 04:25:31.250 [0x7f86ccb2b700] DEBUG - EventSource: Stopping.
Nov 13, 2019 04:25:31.250 [0x7f86cce19700] DEBUG - EventSource: Stopping.
Nov 13, 2019 04:25:36.324 [0x7f86ccb2b700] DEBUG - EventSource: Stopping.
Nov 13, 2019 04:25:36.545 [0x7f86ccb2b700] DEBUG - EventSource: Stopping.
Nov 13, 2019 04:25:36.844 [0x7f86ccb2b700] DEBUG - EventSource: Stopping.
Nov 13, 2019 04:25:42.333 [0x7f86ccb2b700] DEBUG - EventSource: Read HTTP reply header.
Nov 13, 2019 04:25:42.333 [0x7f86ccb2b700] DEBUG - EventSource: Failure in ParseHeader: HTTP/1.1 500 Internal Server Error
Server: nginx
Date: Wed, 13 Nov 2019 11:25:42 GMT
Content-Type: text/html
Content-Length: 186
Connection: close
I rebooted my Synology this morning… and this cleared all the issues. Watching videos now on the TV via AppleTV.
The logs were filled after this with
Nov 14, 2019 03:34:16.239 [0x7f86bf22f700] WARN - Warning: ex: boost::filesystem::last_write_time: No such file or directory: "/volume1/@appstore/Plex Media Server/Resources/Plug-ins-c186313fe", couldn't check file: "/volume1/@appstore/Plex Media Server/Resources/Plug-ins-c186313fe"
Nov 14, 2019 03:34:18.239 [0x7f86bf22f700] WARN - Warning: ex: boost::filesystem::last_write_time: No such file or directory: "/volume1/@appstore/Plex Media Server/Resources/Plug-ins-c186313fe", couldn't check file: "/volume1/@appstore/Plex Media Server/Resources/Plug-ins-c186313fe"
Nov 14, 2019 03:34:20.239 [0x7f86bf22f700] WARN - Warning: ex: boost::filesystem::last_write_time: No such file or directory: "/volume1/@appstore/Plex Media Server/Resources/Plug-ins-c186313fe", couldn't check file: "/volume1/@appstore/Plex Media Server/Resources/Plug-ins-c186313fe"
Nov 14, 2019 03:34:22.266 [0x7f86bf22f700] WARN - Warning: ex: boost::filesystem::last_write_time: No such file or directory: "/volume1/@appstore/Plex Media Server/Resources/Plug-ins-c186313fe", couldn't check file: "/volume1/@appstore/Plex Media Server/Resources/Plug-ins-c186313fe"
This is approx the time I rebooted the Synology.
it came up at this time and was fine so far.
Nov 14, 2019 03:38:08.284 [0x7f062a2d5700] INFO - Plex Media Server v1.18.2.2029-36236cc4c - Synology DS918+ x86_64 - build: linux-x86_64 synology - GMT -07:00
Nov 14, 2019 03:38:08.284 [0x7f062a2d5700] INFO - Linux version: DSM 6.2.2.24922-3, language: en-US
Nov 14, 2019 03:38:08.284 [0x7f062a2d5700] INFO - Processor Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
Nov 14, 2019 03:38:08.284 [0x7f062a2d5700] INFO - /var/packages/Plex Media Server/target/Plex Media Server
Nov 14, 2019 03:38:07.882 [0x7f0634981740] DEBUG - BPQ: [Idle] -> [Starting]
Nov 14, 2019 03:38:07.956 [0x7f0634981740] DEBUG - FeatureManager: Using cached data for features list
Nov 14, 2019 03:38:08.007 [0x7f0634981740] DEBUG - Opening 20 database sessions to library (com.plexapp.plugins.library), SQLite 3.26.0, threadsafe=1
Nov 14, 2019 03:38:08.451 [0x7f0634981740] INFO - SQLITE3:(nil), 283, recovered 344 frames from WAL file /volume1/Plex/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db-wal
Nov 14, 2019 03:38:08.871 [0x7f0634981740] DEBUG - Running migrations. (EPG 0)
Nov 14, 2019 03:38:09.770 [0x7f0629cf9700] WARN - Crash: Crash reporting disabled
Nov 14, 2019 03:38:13.744 [0x7f0634981740] DEBUG - ChangestampAllocator: initialized to 468409
Nov 14, 2019 03:38:13.744 [0x7f0634981740] DEBUG - Opening 2 database sessions to library (com.plexapp.plugins.library.blobs), SQLite 3.26.0, threadsafe=1
Nov 14, 2019 03:38:13.924 [0x7f0634981740] DEBUG - Running migrations. (EPG 0)
Nov 14, 2019 03:38:14.054 [0x7f0629a0b700] DEBUG - Codecs: Downloading current version of h264 decoder
Nov 14, 2019 03:38:14.054 [0x7f0629a0b700] INFO - CodecManager: obtaining decoder 'h264'
Nov 14, 2019 03:38:14.055 [0x7f0629a0b700] DEBUG - Relay: read 0 cached entries from hosts file
Nov 14, 2019 03:38:14.055 [0x7f0629a0b700] DEBUG - HTTP requesting GET https://plex.tv/api/codecs/h264_decoder?build=linux-x86_64-standard&deviceId=e9d1e6ef-644b-484e-9c3c-67401beea3fe&oldestPreviousVersion=1%2E14%2E1%2E5488-cc260c476&version=395e79c-2735
Nov 14, 2019 03:38:14.130 [0x7f0634981740] DEBUG - CERT: Installed certificate with fingerprint a1:b8:11:4d:93:81:d7:e1:dc:55:ea:08:7f:c8:a7:ca:88:47:d1:07.
Nov 14, 2019 03:38:14.130 [0x7f0634981740] DEBUG - CERT: Installed new private key.
Nov 14, 2019 03:38:14.130 [0x7f0634981740] DEBUG - CERT: Subject name is /C=US/ST=California/L=Los Gatos/O=Plex, Inc./CN=*.5b69143051284739acc0547e1eaf1813.plex.direct
Nov 14, 2019 03:38:14.130 [0x7f0634981740] DEBUG - CERT: OCSP requests for stapling will be made to 'http://ocspx.digicert.com/'.
Nov 14, 2019 03:38:14.135 [0x7f0634981740] INFO - OCSP: Successfully retrieved response from cache.
Nov 14, 2019 03:38:14.135 [0x7f0634981740] DEBUG - CERT: Installed intermediate certificate.
Nov 14, 2019 03:38:14.136 [0x7f0634981740] DEBUG - HttpServer: Listening on IPv6 as well as IPv4.
Nov 14, 2019 03:38:14.136 [0x7f0634981740] DEBUG - HttpServer: Listening on port 32400 with queue of 128 connections.
Nov 14, 2019 03:38:14.141 [0x7f0634981740] DEBUG - HttpServer: Listening on port 32401 with queue of 128 connections.
Nov 14, 2019 03:38:14.239 [0x7f0629141700] DEBUG - Grabber: Cleaning up orphaned grabs.
Nov 14, 2019 03:38:14.240 [0x7f0634981740] DEBUG - Media Provider: Registering provider com.plexapp.plugins.library
Nov 14, 2019 03:38:14.240 [0x7f0634981740] DEBUG - Auth: Refreshing tokens inside the token-based authentication filter.
Nov 14, 2019 03:38:14.240 [0x7f0628828700] DEBUG - HTTP requesting GET https://plex.tv/media/providers?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Nov 14, 2019 03:38:14.252 [0x7f0629141700] DEBUG - Grabber: Cleaned up 0 decrepit directories in 0.0 sec.
Nov 14, 2019 03:38:14.254 [0x7f0634981740] DEBUG - MyPlex: using cached data for request for https://plex.tv/api/v2/server/access_tokens?auth_token=xxxxxxxxxxxxxxxxxxxx&includeProfiles=1&includeProviders=1
<SNIP>
Thank you.
NOW I see it.
For some very strange reason, Synology did not install the package correctly.
  1. Stop PMS
  2. Uninstall the package
  3. Restart DSM
  4. While it’s restarting , Go download a fresh copy using a different browser just to be safe.
  5. When it returns, Install the freshly downloaded one.
I had the same issue. This post solved it.
DS918+
before un-installing PMS and re-installing it. just want to verify that by doing so, the /Plex folder will be safe and I’m not going to loose my database(s) for watched and on-deck etc
can you also point to the log message that showed you the issue? right now I’m assuming it’s the logs after it freaked out that just kept repeating over and over again.
Sorry for the delay, I was very overloaded.
  1. Yes, uninstalling the application Package will not remove your metadata. I wrote the installer and did it this way so your data does stay safe.
  2. @trmentry Do I still have your logs? I am looking but cannot find them. If I had them, I’ve most likely deleted them as I do not find them here.
Thanks for the info.
I didn’t attach my logs to the thread. Just the snippets I quoted in the few posts of interesting entries.
Thanks again for the help. I’ll work on the uninstall/reinstall this weekend after my shift.
This fixed the same problem I had on my DS216se that started after I simply shut it down for a few weeks while I was away -_-
