Can't rename a TV show
Hello
I cant edit a TV show. I try and “edit” it and rename it, however the lock icon is closed so when i change the name it doesnt save.
Im the only owner/user of the account.
The file is just called “series 2” and i want to correctly name it
any advice or help?
Please provide a screenshot. The whole screen please, not just a part. I am unsure what lock icon you are referring to.
Most of ther time you can click on the lock and it will unlock. Note that when you do chamge a name ( series or movie ) that most often what you enter is also shown in white under the title bar. When you are done correcting, click on the white title that followed what you entered. The Lock stops any auto updates from metadata files. Also if you need to change the year, it MUST be in yyy-mm-dd.
If it is a series I use, Series name S01E01 title( if there is a title name ) ( You can reverse the series name and episode indicater either way willput the series episodes in the proper order. ( if series name is first, each entry must be exactly the same. IE: Dead.Man’s.Gun S01E01 The Great McDonacle OR use series number first IE: S01E01 Dead.Man’s.Gun The Great McDonacle -
