Server Version#:Linux raspbian 4.19.88-OPENFANS+20191229-v8 #1 SMP PREEMPT Sun Dec 29 17:44:26 CST 2019 aarch64 GNU/Linux
(based on debian and here is the github)
HERE IS THE LOG
● plexmediaserver.service - Plex Media Server
Loaded: loaded (/lib/systemd/system/plexmediaserver.service; disabled; vendor preset: enabled)
Active: failed (Result: signal) since Thu 2020-01-30 02:06:55 CST; 14min ago
Process: 3667 ExecStartPre=/bin/sh -c /usr/bin/test -d "${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" || /bin/mkdir -p "${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" (code=exited, status=0/SUCCESS)
Process: 3674 ExecStart=/bin/sh -c export PLEX_MEDIA_SERVER_INFO_VENDOR="$(grep ^NAME= /etc/os-release | awk -F= "{print \$2}" | tr -d \" )"; export PLEX_MEDIA_SERVER_INFO_DEVICE="PC"; export PLEX_MEDIA_SERVER_INFO_MODEL="$(uname -m)"; export PLEX_MEDIA_SERVER_INFO_PLATFORM_VERSION="$(grep ^VERSION= /etc/os-release | awk -F= "{pr
Main PID: 3674 (code=killed, signal=ABRT)
Jan 30 02:06:55 raspbian systemd[1]: plexmediaserver.service: Service RestartSec=5s expired, scheduling restart.
Jan 30 02:06:55 raspbian systemd[1]: plexmediaserver.service: Scheduled restart job, restart counter is at 3.
Jan 30 02:06:55 raspbian systemd[1]: Stopped Plex Media Server.
Jan 30 02:06:55 raspbian systemd[1]: plexmediaserver.service: Start request repeated too quickly.
Jan 30 02:06:55 raspbian systemd[1]: plexmediaserver.service: Failed with result 'signal'.
Jan 30 02:06:55 raspbian systemd[1]: Failed to start Plex Media Server.
and the plexmediaserver.service
[Unit]
Description=Plex Media Server
After=network.target network-online.target
[Service]
Environment="PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR=/var/lib/plexmediaserver/Library/Application Support"
Environment=PLEX_MEDIA_SERVER_HOME=/usr/lib/plexmediaserver
Environment=PLEX_MEDIA_SERVER_MAX_PLUGIN_PROCS=6
Environment=PLEX_MEDIA_SERVER_TMPDIR=/tmp
ExecStartPre=/bin/sh -c '/usr/bin/test -d "${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" || /bin/mkdir -p "${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}"'
ExecStart=/bin/sh -c '\
export PLEX_MEDIA_SERVER_INFO_VENDOR="$(grep ^NAME= /etc/os-release | awk -F= "{print \\$2}" | tr -d \\" )"; \
export PLEX_MEDIA_SERVER_INFO_DEVICE="PC"; \
export PLEX_MEDIA_SERVER_INFO_MODEL="$(uname -m)"; \
export PLEX_MEDIA_SERVER_INFO_PLATFORM_VERSION="$(grep ^VERSION= /etc/os-release | awk -F= "{print \\$2}" | tr -d \\" )"; \
export LD_LIBRARY_PATH=/usr/lib/plexmediaserver/lib; \
exec "/usr/lib/plexmediaserver/Plex Media Server"'
Type=simple
User=root
Group=root
Restart=on-failure
RestartSec=5
StartLimitInterval=60s
StartLimitBurst=3
SyslogIdentifier=Plex Media Server
StandardOutput=journal
StandardError=journal
[Install]
WantedBy=multi-user.target
and plexmediaserver.default
# default Environment for Plex Media Server
# The number of plugins that can run at the same time
export PLEX_MEDIA_SERVER_MAX_PLUGIN_PROCS=6
# Limit the stack size
export PLEX_MEDIA_SERVER_MAX_STACK_SIZE=3000
# Where Plex should store the transcodes
export PLEX_MEDIA_SERVER_TMPDIR=/tmp
# Where Plex keeps its metadata
export PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR="/var/lib/plexmediaserver/Library/Application Support"
# the user that PMS should run as, defaults to 'plex'
# note that if you change this you might need to move
# the Application Support directory to not lose your
# media library (match what is in /etc/passwd)
# (plex_media_server_user has been retired in favor of plex_user on Debian)
export PLEX_MEDIA_SERVER_USER=root
# Uncomment this to use syslog for logging instead of
# sending logs to Plex Media Server.log
#export PLEX_MEDIA_SERVER_USE_SYSLOG=true
PLZ HELP!
i too need to install on my ubuntu aarch64 not armhf
