Hi all,
I have just installed PMS on a clean Raspbian installation but cannot get PMS to start. See below the error message that the service throws. Do you have any idea what could be wrong?
Thank you!
Which model Pi are you using, and which Plex Media Server package did you download and install? The error above means that Plex Media Server attempted to execute an illegal instruction; this could be caused by an architecture mismatch, or running on an unsupported platform/processor.
It’s possible the original Pi’s processor does not support some instructions used by Plex. I’m pretty sure the original Pi’s processor was based on the ARMv6 architecture; the packages available for Plex Media Server are ARMv7 and ARMv8. I can’t test however, I don’t have that model with which to test.
I can’t speak authoritatively on this point, but I very much doubt it. There are some fairly significant differences between the two architectures (though they are very similar in some ways, too).
You are absolutely correct. Anything older than a Raspberry Pi 2 (ARMv7) is not supported and general ARMv6 PMS support was dropped many years ago.
@GrandCanyon I recommend to not get anything older than a RPi 4 at this time. Please also take a look at the entry level Intel NUCs. They are significantly more up to the task.
