Leaving aside all of the resource constraints associated with Raspberry Pi, I am having problems getting it to start up through systemd. Can someone suggest where I can start digging to get it to even start?
The package that I’m working with is plexmediaserver_1.15.2.793-782228f99_armhf.deb
This is what I get from checking the status of the job:
pi@Plex_Server:/var/log $ sudo systemctl status plexmediaserver.service
● plexmediaserver.service - Plex Media Server
Loaded: loaded (/lib/systemd/system/plexmediaserver.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sat 2019-03-30 02:41:13 CDT; 3min 36s ago
Process: 3094 ExecStart=/bin/sh -c PLEX_MEDIA_SERVER_INFO_VENDOR="$(grep ^NAME= /etc/os-release | awk -F= "{print \
Process: 3090 ExecStartPre=/bin/sh -c /usr/bin/test -d "${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" || /bin/mkdir
Main PID: 3094 (code=exited, status=132)
Mar 30 02:41:08 Plex_Server systemd[1]: plexmediaserver.service: Unit entered failed state.
Mar 30 02:41:08 Plex_Server systemd[1]: plexmediaserver.service: Failed with result 'exit-code'.
Mar 30 02:41:13 Plex_Server systemd[1]: plexmediaserver.service: Service hold-off time over, scheduling restart.
Mar 30 02:41:13 Plex_Server systemd[1]: Stopped Plex Media Server.
Mar 30 02:41:13 Plex_Server systemd[1]: plexmediaserver.service: Start request repeated too quickly.
Mar 30 02:41:13 Plex_Server systemd[1]: Failed to start Plex Media Server.
Mar 30 02:41:13 Plex_Server systemd[1]: plexmediaserver.service: Unit entered failed state.
Mar 30 02:41:13 Plex_Server systemd[1]: plexmediaserver.service: Failed with result 'exit-code'.
