Hello, the problem is that when i shut off my plexconnect.py from pc all of my settings are reseted such as transcoded quality, movie and tv shows options. The other problem is that when i set transcoded to Direct play no movie started at all. Any suggestions? Thank you
a - how do you shut down PlexConnect? It needs to proper exit (CTRL-C) to have a chance to save the settings.
b - you aTV can pretty much only play mp4/h264/aac. Everything else needs transcoding. If you don't let the PMS do so, it can't be replayed, that's how things work.
Ok you pritty much save my day! Thank you. I didnt do anything proper to say it that way :P
