Can't Select Audio or Video Quality Options When Playing a Video
I can’t select different audio or video quality options when playing a video anymore. For audio the only option I see is Stereo and for video it doesn’t show the higher quality options that are available in the pre-play screen. Is this a bug? Anyone else seeing this issue?
Same here I got this issue too
What type of server are you using and what version of the server?
The app should display options up to what the server reports for the file. One thing you can try is reanalyzing the video file from the web manager and see if that gets the options fully back.
That did the trick, thanks!
I’m using Windows server on the latest public version.
