Can't upgrade TV Shows Library
Server Version#: 1.21.0-3744
Player Version#:1.41.0.2876-e960c9ca
I have the up arrow indicating there is an update for the agent for my TV Shows library. I’ve successfully updated by Films library without issue, but every time I click upgrade on TV shows I get a pop up message in red saying ‘There was a problem upgrading the library.’
I had a look in the logs, and this is the error I can find:
Mar 15, 2022 17:57:38.014 [0x7f7b0eb76700] ERROR - XML: Entity: line 1:
Mar 15, 2022 17:57:38.014 [0x7f7b0eb76700] ERROR - XML: parser
Mar 15, 2022 17:57:38.014 [0x7f7b0eb76700] ERROR - XML: error :
Mar 15, 2022 17:57:38.014 [0x7f7b0eb76700] ERROR - XML: Start tag expected, ‘<’ not found
Mar 15, 2022 17:57:38.014 [0x7f7b0eb76700] ERROR - XML: status=ok
Mar 15, 2022 17:57:38.014 [0x7f7b0eb76700] ERROR - XML: ^
Mar 15, 2022 17:57:38.014 [0x7f7b0eb76700] ERROR - Error parsing content.
Mar 15, 2022 17:57:38.014 [0x7f7b0eb76700] ERROR - Error parsing XML: Error parsing file.
Mar 15, 2022 17:57:38.014 [0x7f7b0eb76700] ERROR - SSDP: Error parsing device schema
The library is fully operational otherwise and I’ve successfully added new content and not had a problem, but I’d like to get this updated for when the old agents are retired.
Any ideas?
