Can't use Browse or Recommended tabs for any libraries on iOS PE
Ever since the Plex Experience update for iOS, I can no longer use the Recommended or Browse tabs for any library from my server. It appears to briefly load, then displays a flashing Plex logo with “Uh Oh… Something’s Not Right. Sorry that didn’t work. Check that server is available and try again.”
If I go to Collections for either library, the collections are there, and I can select an item and it will play. There are no issues on any other device, only iOS with the new Plex Experience.
If I read it right, it looks like we will have the ability to do that in the next update “Plex for iOS 2025.13.0.1018”.
After making this post, I installed Test Flight and updated to version 2025.13.0.1018. I can now access these tabs for my TV Shows library, but my movies Library is still broken.
