I’m new here, not sure what I’m doing wrong but it seems to me like there is a glitch somewhere.
I recently upgraded my QNAP Nas to an new one; the model I’m running is on the supported list and is fully supported.
When I open the plex server from the nas, I get an error saying “no soup for you! you do not have access to this server” There is no error code.
When I log into my plex account though the server, I can only access it as a web device and can’t add any of the content on my server.
I have tried removing the old nas from the list of authorized devices to no avail.
Is this some kind of port blocking issue with my router? I’m not sure where to start troubleshooting this as it gives me so little information. Please help!
You can start/stop/restart PMS in App Center just as you do with any other app.
I would like you to do the following:
Stop Plex
Create a Shared Folder named PlexData (named exactly this way). It doesn’t matter where you put it. It is a placeholder.
Start Plex. Let it run for 30 seconds, Stop Plex
Install the QNAP Text Editor app
Open File Station
Navigate to the PlexData share.
Click “Plex Media Server”
You will see Preferences.xml
Copy then paste using the mouse to make a backup copy (just in case)
Right-click it → “Open with Text Editor”
Very carefully, remove the following Preference="Value" pairs. A single space between each Name="value" pair is all that’s required.
a. PlexOnlineUsername
b. PlexOnlineToken
c. PlexOnlineEmail
h. PlexOnlineHome (this is optional. might not exist. no worries if not)
